Latent heat of vaporisation question
In summary, the conversation discusses a pupil's experiment involving heat supply, temperature rise, and evaporation rate. An upper limit for the heat capacity of the inner flask and its contents is estimated, and the mass of water collected after 30 minutes of steady boiling is calculated. The provided information includes the power supply, duration of the experiment, and the specific heat capacity of water.
lionely
576
A pupil performing an experiment finds that, when the heat supply is 16W, it takes 30 mins for the temp of the water to rise from 20°C to 100°C, and that the rate of evap is very
slow even at the latter temp. Estimate an upper limit to the value of the heat capacity of the inner flask and its contents. Calculate the mass of water collected after 30mins of steady boiling when the power supply is 60W.
(lv of water = 2.26 x 10^6 J/Kg)
The attempt at a solution
For the upper limit i did this
total heat supplied= 16 x 30 x 60= 28,880J
C= E/Δt= 28,800/80 = 360 J/K.
Now for the mass of water I get confused with what to do
Does the problem as reproduced here on this forum include all the information provided in the original problem statement?
Nevermind I figured it out. xD
Related to Latent heat of vaporisation question
What is the latent heat of vaporisation?
The latent heat of vaporisation is the amount of energy required to change a substance from a liquid to a gas at a constant temperature and pressure. It is also known as the enthalpy of vaporisation.
Why is latent heat of vaporisation important?
The latent heat of vaporisation is important because it is the energy that is needed for a substance to undergo a phase change from liquid to gas. This energy is necessary for processes such as boiling, evaporation, and condensation.
How is latent heat of vaporisation calculated?
The latent heat of vaporisation can be calculated by dividing the amount of energy required to vaporise a substance by the mass of the substance. This is known as the specific latent heat.
What factors affect the latent heat of vaporisation?
The latent heat of vaporisation is affected by factors such as the type of substance, temperature, and pressure. Generally, substances with stronger intermolecular forces will have a higher latent heat of vaporisation.
How is latent heat of vaporisation used in everyday life?
The latent heat of vaporisation is used in everyday life in processes such as cooking, steam engines, and air conditioning. It is also used in industries such as food production, chemical manufacturing, and energy production.
