Latent Heat of Vaporization /w Temperature
In summary, the specific latent heat of vaporization of water is higher at lower temperatures due to the gas that it vaporizes into being more dilute, resulting in a difference in energy state and latent enthalpy of evaporation. This difference in energy decreases as the temperature approaches the critical temperature of water. Additionally, the energy needed to break bonds decreases at higher temperatures, resulting in a lower specific latent heat of vaporization.
worwhite
25
Hi,
I would like to ask, why is it that the specific latent heat of vaporization of water at, say 10 degrees Celsius, is considerably higher that at 100 degrees Celsius?
It would be great if you could provide an explanation from the molecular view.
Thanks.
Science news on Phys.org
I'm not sure that the molecular viewpoint is going to be all that informative for you, because the reason has much more to do with the gas that the water vaporizes into.
At 100 C, when water boils or evaporates, it turns into 100 C, 1 atm pressure water vapor.
At 10 C, when water boils or evaporates, it turns into 10 C, ~0.01 atm pressure water vapor.
In other words, when the phase change occurs, at lower temperatures the end result is a more dilute gas. You can see that there is a difference in the energy state between a hot dense gas such as the 100C 1 atm water vapor and the cold dilute 10 C ~0.01 atm water vapor. This difference in energy is reflected in the difference in latent enthalpy of evaporation.
I guess from a molecular viewpoint the extra energy is used to make enough space for the vapor molecules to be more dilute at lower temperatures. As you get closer to the critical temperature (374 C for water), the amount of energy needed for this drops closer and closer to zero.
Thanks for the answer krysith - it makes sense to me I suppose. My original thought was that water at 100 C had slightly larger inter-molecular spacing (and thus P.E.), therefore it takes less energy for it to become gas compared to water at 10 C.
actually it isn't so much about the difference in vapor pressure at those temperatures. You can work out a quick calculation to show that the PV term is a fairly small contributor to the enthlapy of evaporation, less than 10%.
The second point is what matters. At 100C you are getting closer to breaking the bonds, so you don't need as much energy to vaporize it.
Hello,
Thank you for your question. The specific latent heat of vaporization is the amount of heat required to convert a unit mass of a substance from liquid to gas at a constant temperature. In the case of water, the specific latent heat of vaporization is higher at lower temperatures because at lower temperatures, the water molecules are more closely packed together and have stronger intermolecular forces holding them in the liquid state. This means that more energy is required to break these bonds and allow the molecules to escape into the gas phase.
At higher temperatures, the water molecules have more kinetic energy and are able to overcome these intermolecular forces more easily, resulting in a lower specific latent heat of vaporization. Additionally, at higher temperatures, some of the water molecules may already be in the gas phase, so less energy is needed to convert the remaining liquid molecules.
From a molecular view, the specific latent heat of vaporization can be explained by the energy required to break the hydrogen bonds between water molecules. These bonds are stronger at lower temperatures, requiring more energy to break them and allow the molecules to escape into the gas phase.
I hope this helps to clarify the concept of specific latent heat of vaporization and its relationship with temperature.
FAQ: Latent Heat of Vaporization /w Temperature
1. What is the definition of latent heat of vaporization?
Latent heat of vaporization is the amount of energy required to convert a liquid into a gas at a constant temperature and pressure.
2. How does temperature affect the latent heat of vaporization?
The latent heat of vaporization increases with increasing temperature. This is because higher temperatures provide more energy for the molecules to overcome the attractive forces holding them in the liquid state.
3. What is the difference between latent heat of vaporization and latent heat of fusion?
Latent heat of vaporization refers to the energy required to change a substance from liquid to gas, while latent heat of fusion refers to the energy required to change a substance from solid to liquid. Both processes involve a phase change, but the difference lies in the state of matter before and after the change.
4. Can the latent heat of vaporization be negative?
No, the latent heat of vaporization cannot be negative. It is always a positive value because energy must be added to a substance in order to convert it from liquid to gas.
5. How is the latent heat of vaporization used in everyday life?
The latent heat of vaporization is used in everyday life in various ways, such as in cooking, refrigeration, and air conditioning. For example, when water evaporates from food during cooking, it absorbs energy from the food, which cools it down. In refrigeration and air conditioning, the latent heat of vaporization is used to remove heat from the air, resulting in cooler temperatures.
