- 23,385
- 5,735
How do I make Greek letters boldface in LaTeX? When I try \mathbf{}, I just get the regular non-bold Greek letter.
Excellent! Thank you so much.andrewkirk said:If you are working in a full LaTeX environment, try \boldmath. to switch on bolding all math chars including Greek letters then \unboldmath to turn it off. Both commands need to be outside the math environment.
In a full LaTeX environment, the following:
$\beta$\boldmath$\beta$\unboldmath$\beta$
comes across as three betas, normal, then bold, then normal.
It doesn't work in MathJax (what PF uses), as that is not full LaTeX, and the commands are issued outside of math environment. Below is what happens with a simple attempt:
##\beta##\boldmath##\beta##\unboldmath##\beta##
gives
Fortunately, PF MathJax appears to have the LaTeX package amsbsy loaded by default, so you can use its \boldsymbol command. The following code
##\beta\boldsymbol{\beta}\beta##
gives
To make Greek letters bold in LaTeX, you can use the command \boldsymbol{\alpha}
to make the lowercase alpha bold or \boldsymbol{\Gamma}
to make the uppercase gamma bold. You can also use the \bm
command from the bm
package.
Yes, you can use the \boldsymbol
command with the *
option to make all Greek letters bold at once. For example, \boldsymbol*{\alpha\beta\gamma}
will make all three letters bold.
There could be a few reasons for this. First, make sure you have included the amsmath
package in your document. If you are using the \boldsymbol
command, make sure you have specified the letter you want to make bold. If you are using the \bm
command, make sure you have wrapped the letter in curly braces, like this: \bm{\alpha}
Yes, you can use the same commands mentioned above (\boldsymbol
or \bm
) in math mode to make Greek letters bold. Just make sure to include the necessary packages and specify the letter you want to make bold.
Yes, there are a few other packages that can be used to make Greek letters bold in LaTeX, such as amsbsy
and bold-extra
. However, these packages may have different commands or options, so it's best to consult their documentation for specific usage instructions.
