LaTeX won't let me create a macro to \begin{split}
  • LaTeX
  • Thread starter joftius
  • Tags
    Latex
In summary, The conversation was about the difficulties in creating equations in LaTeX. The speaker was trying to create an equation using the split environment but encountered an error. They asked if there was a way to simplify the process and mentioned trying the align environment with similar results. They also mentioned using a program with keyboard shortcuts to make the process easier. A link to a LaTeX tutorial was provided as a resource.
joftius
So I'm trying to do this:
\newcommand{\bq}{\begin{equation*}}
\newcommand{\eq}{\end{equation*}}
\newcommand{\bsp}{\begin{split}}
\newcommand{\esp}{\end{split}}
\bq
\bsp
1 & = 1 \\
2 & = 1 + 1
\esp
\eq
but then LaTeX gives me this error
Runaway argument?
1 & = 1 \\ 2 & = 1 + 1 \esp \eq
! Paragraph ended before \split was complete.
What I really want is just one command to do
\begin{equation*}
\begin{split}
and one command to do the corresponding ends.
Is there any way to do this?
Note: I've tried using \begin{align*} instead, and I get a similar type of weird error.
FAQ: LaTeX won't let me create a macro to \begin{split}
Why won't LaTeX let me create a macro to \begin{split}?
LaTeX has strict syntax rules and creating macros for certain environments, like \begin{split}, can be challenging. It's possible that your macro is conflicting with other macros or commands in your document.
How can I create a macro for \begin{split} in LaTeX?
To create a macro for \begin{split}, you can use the \newcommand or \renewcommand commands. Make sure to follow proper syntax and avoid any conflicting commands or packages.
What is the purpose of the \begin{split} environment in LaTeX?
The \begin{split} environment in LaTeX is used to split a single equation into multiple lines, making it easier to read and understand. It is commonly used in conjunction with the equation or align environments.
Can I use multiple macros for \begin{split} in the same document?
Yes, you can create multiple macros for \begin{split} in the same document. However, make sure to give each macro a unique name to avoid conflicts.
What should I do if my macro for \begin{split} is not working?
If your macro for \begin{split} is not working, check for any errors in your syntax or conflicts with other macros or commands. You can also try using the \DeclareMathOperator command instead of \newcommand or \renewcommand.
11K
