MHB Lauren's question at Yahoo Answers regarding inexact ODE
  • Thread starter Thread starter MarkFL
    Ode
The discussion addresses Lauren's question about solving a linear first-order ordinary differential equation (ODE) given by 2y(y^2-x)dy=dx. The equation is reformulated into the standard form, revealing that it is inexact due to the differing partial derivatives of M and N. An integrating factor, μ(y)=e^(y^2), is determined to make the equation exact. After applying this integrating factor, the solution is derived, leading to the implicit solution (x+1-y^2)e^(y^2)=C. The discussion effectively demonstrates the steps required to solve the inexact ODE using integrating factors.
MarkFL
MHB
Here is the question:
Help me with my Linear Differential Equation of Order One: The Integrating Factor?
2y(y^2-x)dy=dx
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Re: Lauren's question from Yahoo! Answers regarding inexact ODE
Hello Lauren,
We are given to solve:
$$2y\left(y^2-x \right)\,dy=dx$$
I would first write the ODE in the form:
$$M(x,y)\,dx+N(x,y)\,dy=0$$
and so we have:
$$(1)\,dx+\left(2xy-2y^3 \right)\,dy=0$$
We see the equation is inexact, since:
$$\frac{\delta M}{\delta y}=0\ne\frac{\delta N}{\delta x}=2y$$
Thus, we observe that:
$$\frac{\frac{\delta N}{\delta x}-\frac{\delta M}{\delta y}}{M}=2y$$
Since this is a function of $y$ alone, we take as our integrating factor:
$$\mu(y)=e^{\int 2y\,dy}=e^{y^2}$$
And so we write the new ODE as:
$$e^{y^2}\,dx+\left(2xy-2y^3 \right)e^{y^2}\,dy=0$$
We see now that:
$$\frac{\delta M}{\delta y}=2ye^{y^2}=\frac{\delta N}{\delta x}=2ye^{y^2}$$
Hence, our new equation is exact. Since it is exact, we must have:
$$\frac{\delta F}{\delta x}=e^{y^2}$$
Integrating with respect to $x$, we obtain:
$$F(x,y)=xe^{y^2}+g(y)$$
Now, to determine $g(y)$, we may take the partial derivative with respect to $y$, substituting using $$\frac{\delta F}{\delta y}=\left(2xy-2y^3 \right)e^{y^2}$$:
$$\left(2xy-2y^3 \right)e^{y^2}=2xye^{y^2}+g'(y)$$
$$g'(y)=-2y^3e^{y^2}$$
Next, we want to integrate this to determine $g(y)$, and we may use integration by parts:
$$u=y^2\,\therefore\,du=2y\,dy$$
$$dv=2ye^{y^2}\,dy\,\therefore\,v=e^{y^2}$$
and we may write:
$$g(y)=-\left(y^2e^y-\int 2ye^{y^2}\,dy \right)=e^{y^2}-y^2e^{y^2}=e^{y^2}\left(1-y^2 \right)$$
Thus, the solution to the original ODE is given implicitly by:
$$xe^{y^2}+e^{y^2}\left(1-y^2 \right)=C$$
$$\left(x+1-y^2 \right)e^{y^2}=C$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
