Laurent series, deep confusion
In summary, the author is lost on how to solve a problem involving a geometric series. They use a partial fraction formulation to get an approximate answer. They then use the fact that \frac{1}{1-z}=\sum_{n=0}^{\infty}z^n to get the two fractions. They use the fact that \frac{1}{z\left( \frac{a}{z} +1 \right) } converges to get the sum.
futurebird
272
I'm so lost. I can follow the steps in the examples in the book, but all of the examples seem easier than this problem-- and in each case there is a point where you "spot" a similarity to the geometric series or something and then you can just patch it in... But, I just don't know how to make that happen here.
Given the function [tex]f(z)=\frac{z}{a^{2}-z^{2}}[/tex] Expand f(z) in a laurent series in the regions: |z| < a and |z| > a.
From another problem I know that:
[tex]\frac{1}{1-z}=\displaystyle\sum_{n=0}^{\infty}z^{n}[/tex], |z| < 1 so:
[tex]\frac{1}{a-z}=\displaystyle\sum_{n=0}^{\infty}z^{n}[/tex], |z| < a (right?)
Now I want to use this fact so I write:
[tex]f(z)=\frac{z}{(a+z)(a-z)}=\frac{z}{(a+z)}\left(\displaystyle\sum_{n=0}^{\infty}z^{n}\right)[/tex]
um... and I don't know what to do next. I've looked at the example in the book and they used -1/z to repace z when working with [tex]\frac{z}{(a+z)}[/tex].
But, if I do that it changes the boundaries for the whole problem. I tried writing:
[tex]=\left(\displaystyle\sum_{n=0}^{\infty}\frac{(-1)^{n}}{z^{n+1}}\right)\left(\displaystyle\sum_{n=0}^{\infty}z^{n}\right)[/tex]
for my next step, but I know this is wrong. I can only do that replacement if I change the boundary... I'm sort of confused about how to go about doing these problems. Help?
Why not use "partial fractions"? That is, write
[tex]\frac{z}{a^2- z^2}= \frac{z}{(a-z)(a+z)= \frac{A}{a- z}+ \frac{B}{a+z}[/itex]
Then write the two separate fractions as power series in z using the fact that
[itex]\frac{1}{1- z}= \sum_{n=0}^{\infty}z^n[/itex]
and add corresponding terms of the two series.
Okay, I have
[tex]\frac{z}{(a+z)(a-z)}=\frac{-\frac{1}{2}}{a+z}+\frac{\frac{1}{2}}{a-z}[/tex]
Then,
[tex]=\frac{1}{2}\left(\displaystyle\sum_{n=0}^{\infty}z^{n}-\displaystyle\sum_{n=0}^{\infty}(-1)^{n}z^{n}\right)[/tex]
[tex]=\displaystyle\sum_{n=0}^{\infty}z^{2n+1}[/tex]
for |z| <a
okay, but what about |z|> a?
Something about this makes no sense... where are the negative powers?
It is important to consider the cases of [itex] |z|<a \text{ and } |z|>a [/itex] seperately.
Let us first consider [itex] |z|>a[/itex].
We want to be able to use the fact that
[tex]\frac{1}{1-x} = \displaystyle\sum_{n=0}^{\infty}x^{n}[/tex]
Thus factor a z out of the addition term to get
[tex]\frac{1}{z\left( \frac{a}{z} +1 \right) } [/tex]
Now since [itex] |z|>a[/itex], then we know that the sum will converge, and so we can proceed as before.
For the record, it is not necessary to use partial fractions for either case.
[tex]f(z)=\frac{z}{(a^2-z^2)}=\frac{z}{a^2 \left( 1- \frac{z^2}{a^2} \right) } [/tex]
You'll note that using
is a much faster way of getting your solution. Furthermore, when you get your closed solution, who says that the index variable must be a positive integer?
FAQ: Laurent series, deep confusion
What is a Laurent series?
A Laurent series is a mathematical concept used in complex analysis to represent a complex-valued function. It is similar to a Taylor series, but it allows for the possibility of negative exponents in addition to positive ones.
How is a Laurent series different from a Taylor series?
A Taylor series only includes non-negative exponents, while a Laurent series allows for both positive and negative exponents. This allows a Laurent series to represent functions with poles or branch points.
What is the purpose of a Laurent series?
A Laurent series can be used to approximate a complex-valued function, particularly one that has singularities or behaves differently in different regions of its domain. It can also be used to calculate the residues of a function and determine its behavior near its singularities.
What is meant by "deep confusion" in relation to Laurent series?
The term "deep confusion" is often used to describe the difficulty and complexity of understanding and working with Laurent series. This is due to the fact that they involve both positive and negative exponents, as well as singularities, which can make them challenging to manipulate and interpret.
What are some practical applications of Laurent series?
Laurent series are used in various areas of mathematics and physics, such as complex analysis, number theory, and quantum mechanics. They are also used in engineering and computer science for signal processing and data analysis.
