Laurent series of rational function in annulus
In summary: I mean I know it works but I was trying to figure out how to do it by the theorem. I read the proof twice but have hard time following it. So I was trying to do it by partial fraction and then get the series into the right form by using the form ##\frac{1}{(1-z)^{k+1}} = \sum_{n=0}^\infty \binom{n+k}{k} z^n## and then replace ##z## with ##-z## to get the principal part into the right form.I think I managed to do it by the theorem. I'll write it here if someone is interested. I'm still not
Incand
334
47
Find the Laurent expansions of
##f(z) = \frac{z+2}{z^2-z-2}## in ##1 < |z|<2## and then in ##2 < |z|< \infty##
in powers of ##z## and ##1/z##.
Theorem:
Let ##f## be a rational function all of whose poles ##z_1,\dots , z_N## in the plane have order one and which has no pole at the origin and which is zero at ##\infty##. Suppose that no pole of ##f## lies in the annular region ##r<|z|<R##. Then
##f(z) = \sum_{-\infty}^\infty a_kz^k \; \; \; \text{ for } \; \; r < |z|<R,##
where
##a_k=\begin{cases}
\sum_{|z_j|< r} z_j^{k-1} \text{Res}(f;z_j), \; \; \; k \le -1\\
-\sum_{|z_j|>R} z_j^{-k-1} \text{Res}(f;z_j), \; \; \; k \ge 0.
\end{cases}
We have the residues
##\text{Res}(f;-1) = -\frac{1}{3}##
##\text{Res}(f;2) = \frac{4}{3}##.
In the first case we have ##r=1## and ##R=2##. The coefficients are then
##a_k = (-1)^{k-1}\frac{-1}{3} = \frac{(-1)^k}{3}## for ##k=-1,-2,\dots##
##a_k = -2^{-k-1} \frac{4}{3} = \frac{-2}{3\cdot 2^k}## for ##k=0,1,2,\dots##.
The answer however says the first part is correct but the second one should be
##a_k = \frac{-4}{3^{k+2}}, \; \; \; k=0,1,2,\dots## which makes no sense to me.
For the second region we have ##r=2## and ##R=\infty##
Then
##a_k = (-1)^{k-1}\frac{-1}{3} + 2^{k-1}\frac{4}{3}## for ##k=-1,-2,\dots##
If we instead of summing over negative ##k## we write the series as
##\sum_{1}^\infty \frac{a_k}{z_k}## we have
##a_k = \frac{(-1)^k}{3} +\frac{2}{3\cdot 2^{k}}##.
The answer here however should be
##\sum_{1}^\infty \frac{a_k}{z_k}## with ##a_k=\frac{(-1)^k}{3}+\frac{4}{3^{k+2}}, \; \; \; k=1,2,\dots##.
I'm also wondering about the ##|z_j|<r## and ##|z_j|>R## parts in the theorem, why do I count singularities at ##r## and ##R## when it says strictly less/greater.
I managed to find an old thread covering the exact same question where they seem to get an answer similar to mine: https://www.physicsforums.com/threads/laurent-series-of-rational-functions.702294/
He seem to reach a answer similar to me so perhaps the answer is wrong. However he does it with partial fractions instead of the theorem (although how I understand it the theorem is essential partial fractions). So what I'm looking for is input if I solved this correctly or If I made a mistake? I also seem to get similar errors on other exercises on the method which makes me doubt.
Theorem:
where
##a_k=\begin{cases}
\end{cases}
Then
There seems to be an error in Fisher's book. If you look at how he derives the theorem, it should be:
where
##a_k=\begin{cases}
\sum_{|z_j|< r} z_j^{-k-1} \text{Res}(f;z_j), \; \; \; k \le -1\\
\end{cases}
I checked it for the case ##|z|>2##, and then the formula leads to a correct result, same as in the other thread (not the result given in the book, though).
Likes Incand
Thanks for taking time looking over the theorem and question! It is only a minussign that is missing? It seems to make more sense without it. The example 12c) in the book would also be wrong then since he seem to use the formula there (I assume you have access to the book since you looked up the theorem & proof).
Using the new formula I get
##f(z) = \frac{-2}{3} \sum_0^\infty \frac{z^k}{2^k} + \frac{1}{3}\sum_{1}^\infty \frac{(-1)^k}{z^k}## for ##1 <|z|<2## and
##f(z) = \frac{1}{3} \sum_1^\infty \frac{(-1) ^k + 2^{k+1}}{z^k}## for ##2<|z|## which is the same as in the thread (they only shifted the series starting at ##0## instead).
I also tried to to do the same with partial fraction hoping it would illuminate what's going in the theorem (and proof).
##f(z) = \frac{-1}{3(z+1)}+\frac{4}{3(z-2)} = \frac{1}{3} \frac{1}{1+z}-\frac{2}{3} \frac{1}{1-z/2}##. (Partial fraction with residue is really neat!)
In the region ##1<|z|<2## the second half of the function is the geometric series which is convergent in the region
##-\frac{2}{3} \sum_0^\infty (z/2)^n##
However I'm not sure how to get the principal part into ##1/z## form.It seems I could do taylor expansion of ##\frac{1}{1+z}## and then replace the old ##z## with ##1/z## and get ##\frac{1}{3} \sum_1^\infty \frac{(-1)^n}{z^n}## but I have no idea what I just did except that it seems to give the right answer.
I know the same solution is in post #8 but I don't understand that part (so far)
Yes, just a sign error. And I think that the example is wrong too.
Look at the relevant part of the proof:
In the terms with ##z## in the denominator, the pole is in the numerator, with an exponent one less than the exponent of ##z## in the denominator.
That's not what equation (12) says, as it puts both ##z## and the pole in the denominator.
These look correct.
Actually, the proof in the book looks correct. It's the statement of equation (12) and the example that are wrong. Maybe a typo in (12), and then a blind application of that wrong equation.
Likes Incand
You're right, I guess it's just a type in the initial formula. I should be more careful reading the proofs in the future instead of skimming them over. Thanks a lot for pointing it out and really going out of your way to help!
I understand the ##\frac{1}{z+1} = \frac{1}{z} \frac{1}{1+1/z} =\frac{1}{z} \sum_0^\infty \frac{(-1)^n}{z^n}## part now as well.
I also seem to get errors on 23b) and c) so I guess there is errors in the answer there as well.
b) ##f(z) = \frac{z^2+2z-4}{(z^2-9)(z+1)}## have residues
##\text{Res}(f;3) = \frac{11}{24} ##
##\text{Res}(f;-3) = \frac{-1}{12}##
##\text{Res}(f;-1) = \frac{5}{8}. ##
Then by the formula we have in the region ##0 \le |z| < 1## that
##a_k = -\frac{5}{8}(-1)^{-k-1}+\frac{1}{12}(-3)^{-k-1} -\frac{11}{24}3^{-k-1} = \frac{1}{24}[ (-1)^k-2\cdot (-3)^{-k}-11\cdot 3^{-k-1}]## for ##k=0,1,2,\dots##.
And in ##1<|z|<3##
##a_k=
\begin{cases}
\frac{5}{8}(-1)^{k+1}, \; \; \; k=-1,-2,\dots\\
\frac{1}{12}(-3)^{-k-1} -\frac{11}{24}3^{-k-1} , \; \; \; k=0,1,2,\dots
\end{cases}
The second one being equal to ##\frac{3}{8}(2\cdot 3^{-k+1}\left((-1)^k-11\right)##
c) I believe this one correct except the 4 in the answer should be a 2.
I checked this one. The first expression seems correct. I'm not sure about ##\frac{1}{24}[ (-1)^k-2\cdot (-3)^{-k}-11\cdot 3^{-k-1}]##.
Likes Incand
Thanks. It really helps to know if I did it right since I'm self-studing the material, I'm relying on the answers (that turned out to be wrong in this case).
Actually I see lost a factor of ##15## in the last expression. I tried it to write it in the same form as the answer to highlight the difference.
Should be ##a_k = -\frac{5}{8}(-1)^{-k-1} + \frac{1}{12}(-3)^{-k-1}-\frac{11}{24}3^{-k-1} = \frac{1}{24}[15(-1)^k+2(-3)^{-k-1}-11\cdot (3)^{-k-1}]##
Yes, this last one is also correct.
It's annoying that books contain errors, not much you can do about that.
To check a Laurent series, you could do as they did in the other thread, write a program computing the (say) 20 first terms of the series. Comparing the result with the value of the function for a few appropriate values will give a very good indication whether the Laurent series is correct or not.
Likes Incand
Yea, still It's the first serious errors I found in the book so it's not that bad.
I keep that In mind for next time, I haven't used Mathematica but I could do it just fine In Matlab I guess.
FAQ: Laurent series of rational function in annulus
1. What is a Laurent series of a rational function in an annulus?
A Laurent series of a rational function in an annulus is a representation of a function as an infinite sum of powers of the variable within a certain region called an annulus. It is a generalization of a Taylor series, allowing for both positive and negative powers of the variable.
2. How is a Laurent series calculated for a rational function in an annulus?
To calculate a Laurent series for a rational function in an annulus, we first need to find the singularities of the function within the annulus. Then, using the known Laurent series of the individual terms, we can combine them to get the overall Laurent series for the function.
3. What is the purpose of using a Laurent series for a rational function in an annulus?
The Laurent series allows us to approximate a function within a certain region, including at points where the function may be undefined or have singularities. It also provides a way to study the behavior of a function near these points.
4. Are there any limitations to using a Laurent series for a rational function in an annulus?
One limitation is that the function must have a finite number of singularities within the annulus, otherwise the series may not converge. Additionally, the series may not accurately represent the function if it has essential singularities within the annulus.
5. Can a Laurent series be used to find the values of a rational function in an annulus?
Yes, a Laurent series can be used to find the values of a rational function within the annulus. By truncating the series after a certain number of terms, we can approximate the value of the function at a specific point within the annulus.
