adrenalinefix
- 2
A spring has its right end fixed and is installed on a horizontal table so that the free end, in equilibrium, is at x = 3.00 m. A 1.65 kg block coming from the left slides along the table. When it passes the origin, it is moving at 5.58 m/s. It strikes the spring, compresses it momentarily, and is then sent back toward the left, where it eventually comes to rest at the point x = 1.50 m. The coefficient of kinetic friction between the block and the table is 0.300. By what distance was the spring compressed?
KE=1/2mv^2
PEspr.=1/2kx^2
Wfric.= (Uk)(Fn)d
I'm just not sure what to do. It should be so easy, with only KE of the block and PE of the spring, along with the Work done by friction. I don't really see how it's possible to solve for a displacement/compression of the spring when the spring constant isn't known.
