Law of conservation of momentum problem
In summary: No. Momentum can be lost if the net force on the system is greater than the law of conservation of momentum.
Ahalp
A falling rock gains momentum as its speed increases. Does this observation contradict the law of conservation of momentum. Explain.
Answer in the textbook:
This observation does not contradict the law of conservation of momentum. The momentum of the Earth increases toward the falling object. The amount of change in the earth’s velocity is so small it is imperceptible, so it appears the law of conservation is being contradicted, but it is not.
My initial answer was that it doesn't contradict the law of conservation of momentum because it doesn't satisfy the conditions for the law. For momentum to be conserved, the net force on the system has to be zero. I wrote that the net force on the system is not zero as the apple is accelerating due to gravity. So, the law of conservation of momentum does not apply to it.
The textbook includes Earth in the system, but I didn't. However, if we don't include Earth in the system, would my answer make sense?
Thanks
Yes. If you define your system as the apple only, then your answer is correct. If you define your system as the apple and the Earth, then the book is correct. You can think of it in either way, which ever way is more convenient.
Alright, thanks!
I just have one quick question relating to the original problem. If the system is set accordingly to include all the objects (like Earth and the apple in the original question), is momentum always conserved?
FAQ: Law of conservation of momentum problem
What is the law of conservation of momentum?
The law of conservation of momentum states that in a closed system, the total momentum of the objects before a collision is equal to the total momentum after the collision. This means that the total amount of momentum in a system remains constant, regardless of any internal changes or forces acting on the system.
How is momentum calculated?
Momentum is calculated by multiplying an object's mass by its velocity. The formula for momentum is p = m * v, where p is momentum, m is mass, and v is velocity. Momentum is measured in units of kg*m/s.
What is an example of a conservation of momentum problem?
An example of a conservation of momentum problem is a collision between two objects. For instance, when two cars collide, the total momentum of the cars before the collision must be equal to the total momentum after the collision, according to the law of conservation of momentum.
How does the law of conservation of momentum relate to Newton's third law?
The law of conservation of momentum can also be thought of as an extension of Newton's third law of motion, which states that for every action, there is an equal and opposite reaction. In a collision, the forces acting on the objects are equal and opposite, resulting in the conservation of momentum.
What happens if the system is not closed?
If the system is not closed, then external forces can act on the objects in the system, causing changes in momentum. In this case, the law of conservation of momentum does not apply, as there are external forces that can affect the total momentum of the system.
