Law of Large Numbers - Rate of convergence
In summary, the rate of convergence of the law of large numbers depends on the distribution functions of the random variables. There are some results without proofs in the paper and further discussion can be found in probability texts or the book "Approximation Theorems of Mathematical Statistics".
Apteronotus
202
What is the rate of convergence of the law of large numbers?
ex.
if
[tex]
lim_{n \rightarrow \infty} \frac{1}{n} \sum Z_n = \mu
[/tex]
1. can we say that the sum converges to [tex]\mu[/tex] as [tex]n^\alpha[/tex] for some [tex]\alpha\in \Re[/tex]?
2. If so, what is the value of [tex]\alpha[/tex]?
Thanks,
It depends very much on the distribution functions of the random variables involved.
This paper has some results without proofs.
Theorems generically known as "Laws of the iterated logarithm" will give some answers. You can find discussions in probability texts (Chung, for example). A very good discussion is in the book "Approximation Theorems of Mathematical Statistics".
I can confirm that the rate of convergence of the law of large numbers is indeed an important concept in statistics. It refers to how quickly the average of a large number of independent and identically distributed random variables approaches its expected value. In other words, it measures the speed at which the sample mean approaches the population mean as the sample size increases.
To answer your first question, yes, we can say that the sum converges to \mu as n^\alpha for some \alpha\in \Re. This is because the law of large numbers states that as the sample size increases, the sample mean will approach the population mean. And according to the definition of convergence, we can say that the rate of convergence is equal to the exponent \alpha.
However, the value of \alpha may vary depending on the specific distribution and properties of the random variables. In some cases, the rate of convergence may be faster (e.g. \alpha = 1) while in others it may be slower (e.g. \alpha = 1/2). It ultimately depends on the characteristics of the data and cannot be determined without further information.
In conclusion, the rate of convergence of the law of large numbers is an important concept to understand in order to accurately interpret and analyze data. It allows us to determine how quickly our sample mean will approach the true population mean, providing valuable insights for statistical inference and decision making.
Related to Law of Large Numbers - Rate of convergence
What is the Law of Large Numbers?
The Law of Large Numbers is a statistical concept that states that as the number of trials or observations increases, the average of the results will converge towards the expected value. In simpler terms, the more data you have, the closer your results will be to the true value.
How does the Law of Large Numbers work?
The Law of Large Numbers works by using probability theory to explain how a large number of independent and identically distributed random variables will have an average value that approaches the expected value as the number of trials increases. This is due to the fact that outliers and random variations tend to cancel each other out as the sample size grows.
What is the significance of the Law of Large Numbers?
The significance of the Law of Large Numbers lies in its application in many fields, including finance, economics, and science. It allows us to make more accurate predictions and decisions based on a large set of data. It also helps to reduce the impact of random errors and outliers on our results.
What is the rate of convergence in the Law of Large Numbers?
The rate of convergence in the Law of Large Numbers refers to how quickly the average of a large sample converges towards the expected value. The rate depends on the underlying distribution of the data and can vary from case to case. Generally, the larger the sample size, the faster the convergence rate.
What are some examples of the Law of Large Numbers in action?
The Law of Large Numbers can be observed in various real-world scenarios. For instance, flipping a coin multiple times will result in an average of 50% heads and 50% tails, which is the expected value. In finance, the law is applied in risk management, where a large and diverse portfolio is less likely to be affected by random market fluctuations. In science, conducting multiple experiments and taking the average of the results can lead to more accurate conclusions.
  • Math POTW for University Students
  • Topology and Analysis
