Law of Motion: Horizontal Force
In summary, an acceleration is exerted on the 2 kg box by the 5 kg, but the net force is 2.4 m/s^2 because the tension applied to the 2 kg box is greater than the force applied to the 5 kg box.
aokidopi
29
Physics: Newton Law of Motion Question?
I am a bit confused about this elementary question. If anyone can guide me in the right direction, I would appreciate it.
Picture: http://tinypic.com/r/14w84g1/7"
2 boxes are placed next to 1 another on a horizontal surface. The box on the left has a
mass of 5 kg while the box on the right has a mass of 2 kg. Assume that there is no friction
is negligible. By pulling on a horizontal string attached to the 2 kg box, Stephane is exerting a force T to the right, while you are exerting a force F to the right by pushing on the 5 kg box.
Using F = 12 N and T = 2.0 N,
(a) Determine the acceleration of the 2 kg box.
[ There is an acceleration exerted on the 2 kg box by the 5 kg. Is this 12N/ 5 kg or 2.4 m/s^2. The tension applies solely to the 2kg box and is 2 N/2 kg or 1 m/s^2. The net acceleration should be 3.4 m/s^2. If that is the case, then the 2 kg box would be pulled by itself. Thus is the total net acceleration 2.4 m/s^2 because that acceleration outweighs the tension on the 2 kg box?]
(b) Which box experiences the largest net force in this situation?
[Should be the same based on part a?]
(c) Determine the magnitude of the force exerted by the 2 kg box on the 5 kg box
in this situation.
If F = 10.0 N and T = 10.0 N, (d) Determine the acceleration of each of the boxes now.
Thank you in advance.
in this situation.
Firstly I am worried by this statement of yours:
"There is an acceleration exerted on the 2 kg box by the 5 kg."
A force may be exerted , but not an acceleration!
1). If the sole force acting was Stephane's, the 2kg box would accelerate away from the 5 kg box - you can easily calculate that rate of acceleration.
2). If the sole force acting was the Force you applied, then you would be accelerating the 7 kg combination. You could calculate that acceleration.
But both forces are applied:
If Stephane's force had really accelerated the 2 kg box away from the 5kg box, then Your force would only have to accelerate the 5kg box - giving a higher acceleration than you will have calculated in 2)., above.
If in that scenario, the 5kg box would be accelerating at a higher rate than the 2kg box [an impossibility] then effectively the 7kg combination is being accelerated by the combined force of you and Stephane.
I am not sure of the last step you mentioned.
a). The acceleration of 2.0 kg box. I tried to use a few household objects to understand this. If the T= 2 N on the 2 kg box and the F=12 N, in the picture, then the tension applied on box 2kg would be canceled, would it not? The whole system is pushed by a 12 N force. The acceleration of the system is 12 N/ (2kg +5kg) = 1.71 m/s^2. The tension on box 2kg is 2 N and causes the box to accelerate at 1 m/s^2. Should these forces be added for the net acceleration on box 2kg, 2.71 m/s^2, or is it simply the acceleration of the whole system, 1.71 m/s^2.
b.) Which experiences the largest net force. The the whole system experiences the same acceleration, don't both boxes have the same net force. However, this doesn't seem correct to me. Is the Force T not taken into account here at all. That 1m/s^2 acceleration or 2 N force of and on the box 2 kg does not matter? I am rather confused.
c.) Is this simply 10 N, F-T=10 N. Because the T is a smaller magnitude, while F is a larger magnitude, box 2 kg stands in the way of the 5 kg box.
If anyone can explain this a bit more clearly, I would be thankful and less frustrated with myself.
bump 10char
The Tension would not be canceled out by a force in the same direction! Augmented perhaps.
You push the 5kg box with a force of 12 N to the right.
The 2 kg box pushes the 5 kg box with a force I will call F2 to the left.
Net force is 12 - F2 to the right.
Steph pulls the 2kg box to the right with a force of 2N
The 5 kg box pushes the 2 kg box with a force F2 to the right. [Newtons 3rd law couple]
Net force on 2kg box is 2 + F2
Those forces result in an acceleration of the blocks, [12-F2 accelerates the 5kg box, 2+F2 accelerates the 2kg box], and the acceleration is the same for each box.
Simultaneous equations, solve for a and the contact force F2
Thank you very much for your help, PeterO. I think the trouble I had was grasping on the idea that the contact forces from A to B is the same as B to A. Thanks again.
That last bit - the A to b, B to A, equal forces - is Newton's Third law. From experience, approx 3% of Senior High students have a confident grasp of Newton's Third law.
Related to Law of Motion: Horizontal Force
What is the Law of Motion: Horizontal Force?
The Law of Motion: Horizontal Force is one of the three laws of motion proposed by Sir Isaac Newton. It states that an object will remain at rest or in uniform motion in a straight line unless acted upon by an external horizontal force.
What is an external horizontal force?
An external horizontal force is a force that is applied to an object in a horizontal direction from the outside. This can include forces such as pushing, pulling, or friction.
How does the Law of Motion: Horizontal Force relate to inertia?
The Law of Motion: Horizontal Force is closely related to the concept of inertia, which is the tendency of an object to resist changes in its state of motion. In the case of horizontal motion, an object will continue to move at a constant speed in a straight line if there is no external horizontal force acting upon it.
Can the Law of Motion: Horizontal Force be applied to objects in space?
Yes, the Law of Motion: Horizontal Force can be applied to objects in space. Although there may not be a visible horizontal force acting on an object in space, there are other forces such as gravity that can affect an object's horizontal motion.
How is the Law of Motion: Horizontal Force used in everyday life?
The Law of Motion: Horizontal Force is used in many everyday situations, such as pushing a shopping cart, riding a bike, or throwing a ball. It also explains why objects on a flat surface will continue to move at a constant speed unless acted upon by an external horizontal force.
