MHB Law of Sines in Polygon Construction - Goals & Benefits
The discussion focuses on the application of the law of sines in polygon construction to approximate the area of a circle using regular polygons. The author aims to demonstrate Archimedes' method by dividing the polygon into isosceles triangles, calculating the area based on the triangle's base and height. As the number of sides increases, the polygon more closely resembles a circle, enhancing the approximation. The law of sines is utilized to determine the length of the base of these triangles, with the vertex angle derived from dividing the full circle into n segments. This method effectively illustrates the relationship between polygonal shapes and circular area calculation.
Mathematics news on Phys.org
As the author says in the first paragraph, his goal is to demonstrate Archimedes' method of calculating the area of a circle. He does that by noting that a circle can be approximated by a regular polygon with "n" sides, all vertices on that circle- and the more sides you take, the better the approximation. He calculates the area of the polygon by drawing lines from the center of the circle to each vertex, dividing the polygon into n isosceles triangles. The area of a triangle is "1/2 base times height". In this case, the base of each triangle is the side of the polygon while height is the distance from the center of the circle to the center of the base. For n large, so that each triangle is very "skinny", that is approximately the length of the two equal sides of the triangle, the radius of the circle.
He specifically uses the sine law to calculate the length of the base. Dividing the $2\pi$ radians of a complete circle by n, the vertex angle of each triangle, at the center of the circle, is $\frac{2\pi}{n}$. Since the three angles of any triangle sum to $\pi$ radians, and the two base angles are equal, they are each $\frac{\pi- \frac{2\pi}{n}}{2}= \frac{(n-2)\pi}{2n}$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
