MHB Law of sines: Unambiguous case
  • Thread starter Thread starter SweatingBear
    Law Law of sines
A triangle is typically unambiguously defined by two sides and the included angle, but this discussion reveals a scenario where two different triangles can be formed from the same measurements. The user applied the Law of Cosines to find side BC and then used the Law of Sines to calculate the angles, resulting in two sets of angles that satisfy the sine function. The confusion arises because the sine function yields two possible angles for a given sine value, leading to a second triangle that appears valid but is geometrically impossible. The resolution involves recognizing that only one combination of angles will sum to 180 degrees, highlighting the importance of considering angle constraints in triangle calculations.
SweatingBear
Hello again, forum.
Is it not true that a triangle is unambiguously defined given two sides and the intermediate angle? That is at least what I learned from studying congruence in geometry. Here's the problem: We have the triangle below (the picture is given in the problem and I have redrawn it) and are asked to find the measurement of the other two angles and the side BC.
Now, intuitively, there is only one possible length for BC for which a triangle can be constructed. The angle at C is fixed because changing that very angle would change the length of BA (which is given and thus constrained). Similar arguments apply to angle B.
From these arguments, it is reasonable to expect only one possible triangle from the given data. To start off we can use law of cosines to determine |BC| and from thereon make use law of sines.
The problem though is when I apply the law of sines in order to compute the other two angles, I am able to form two different triangles with different measurements of their angles.
Triangle #1: $$\angle A = 23.8^\circ$$, $$\angle B = 34.3^\circ$$ and $$\angle C = 121.9^\circ$$.
triangle 23.8°,34.3°,121.9° - Wolfram|Alpha
Triangle #2: $$\angle A = 23.8^\circ$$, $$\angle B = 145.7^\circ$$ and $$\angle C = 10.5^\circ$$.
triangle 10.5°,23.8°,145.7° - Wolfram|Alpha
Now this is very strange, I have not come across a triangle (with two given sides and the intermediate angle) which is not unambiguously defined until now. How is this even possible? Clearly in triangle #2, it is not possible for the angle at B to equal 145.7 degrees since this would change the length of AC. But the algebra does not "see" that, simply due to $$\sin (180^\circ - v) \equiv \sin (v)$$.
So, forum, how do we resolve this issue? Help much appreciated!
Mathematics news on Phys.org
I would first use the Law of Cosines to determine:
$$\overline{BC}\approx4.264311887306$$
Then using the Law of Sines, I find:
$$\angle C\approx34.6^{\circ},\,145.4^{\circ}$$
$$\angle B\approx58.4^{\circ},\,121.6^{\circ}$$
The only combination which has the sum of the thee angles as $$180^{\circ}$$ is:
$$\angle A=23.8^{\circ},\,\angle B\approx121.6^{\circ},\,\angle C\approx34.6^{\circ}$$
Thanks for the reply!
The only difference between my and your approach is that you calculated every angle in the triangle using law of sines, whereas I calculated only one angle and the final one assuming the angle sum is 180. Why exactly did my approach fail in this case? I have had no issues with it before until this very problem.
I was taught, in this case, to look for both possible values of each of the two unknown angles via the sine identity you cited, and only then to look for that combination of angles who sum is $180^{\circ}$.
Seemingly a much better approach than mine. Thanks a heap!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
