greypilgrim
- 538
- 36
Hi,
Some "derivations" of the law of the lever argue with conservation of energy: If one arm of the lever of length ##r_1## is pulled by a distance ##s_1## with force ##F_1##, the other arm moves by a distance ##s_2=s_1 \frac{r_2}{r_1}##. From conservation of energy ##E=F_1 s_1=F_2 s_2## it follows $$F_2=F_1 \frac{s_1}{s_2}=F_1 \frac{r_1}{r_2}\enspace.$$
However, the law of the lever also holds in static situations where ##s_1=s_2=0## and no work is being done and above derivation breaks down. A derivation that both includes moving and static situations uses the fact that all torques must vectorially add up to zero which follows from conservation of angular momentum.
So I wonder if the derivation using conservation of energy only works coincidentally, because energy and torque share the same unit. From a Noetherian perspective, the derivations are very different, the first following from homogeneity in time, the other from isotropy in space.
As a more general question, is it mere coincidence that energy and torque have the same unit or is there more to it?
