Lawnmower Go-Kart drivetrain problem
  • Automotive
  • Thread starter S_McLachlan
In summary, the individual is seeking advice on how to use a lawnmower engine to build a go-kart. They mention using a bevel gear combo and attaching it to the back axle, but are struggling with the drive train. Other individuals suggest using pulleys and a drive belt or roller chain. They also provide recommendations for the size and type of chain and sprockets to use. Additionally, it is advised to use a chain guard for safety. The conversation ends with a suggestion to seek assistance from a professional karting company. The individual also mentions their own failed attempt at building a go-kart.
S_McLachlan
I've got myself a lawnmower engine and I'm wanting to make a go-kart. I was going to rig it to a bevel gear combo and then just put it straight onto the back axle but I'm struggling to figure out the drive train.
What is the best way to do this?
What do people normally do? Seems to be a lot of people on youtube making lawnmower engines into stuff.
Forgive my ignorance.
Cheers, Stuart.
For the sake of simplicity and flexibility, I'd be mighty tempted to use pulleys and a drive belt.
Welcome Mclach..been a while since I ran one of these..a " fun Kart" typically uses # 35 roller chain..the carnival karts and go cart land cartsuse # 40 or 41 chain but I never had probs with # 35 and this is what the world cart racers runuse a 10 tooth clutch and 60 tooth drive sprocket on light karts..on heavier carts use 12 tooth and 72 tooth final drive sprocket..the 5 to 1 drive ratio give more spped but the 6 to 1 is good compromise.. the 7.2 to 1 is for fat kids...( final drive ratio = drive sprocket teeth count devided by clutch teeth count)
PUT A CHAIN GUARD ON THE WHOLE THING!
www.appcokarting.com
call APPCO Karts, Parts & Accessories at 1-800-676-6636
Doing a go kart by yourself is quite compliacte. I have tried it once but it was really bad. That's why i bought a new one and everything is ok! :)
FAQ: Lawnmower Go-Kart drivetrain problem
What is a Lawnmower Go-Kart drivetrain problem?
A Lawnmower Go-Kart drivetrain problem is an issue with the mechanism that transfers power from the engine to the wheels of a go-kart that has been built using a lawnmower as its base.
What are the common signs of a Lawnmower Go-Kart drivetrain problem?
Some common signs of a Lawnmower Go-Kart drivetrain problem include difficulty starting the engine, unusual noises or vibrations while driving, and a decrease in speed or power.
How can I diagnose a Lawnmower Go-Kart drivetrain problem?
To diagnose a Lawnmower Go-Kart drivetrain problem, you should first inspect all components of the drivetrain, including the belts, pulleys, and axles. Look for signs of wear or damage and make any necessary repairs or replacements.
What are the most common causes of Lawnmower Go-Kart drivetrain problems?
The most common causes of Lawnmower Go-Kart drivetrain problems include worn or damaged belts, misaligned or loose pulleys, and worn bearings or axles. These issues can result from regular wear and tear or improper maintenance.
How can I prevent Lawnmower Go-Kart drivetrain problems?
To prevent Lawnmower Go-Kart drivetrain problems, it is important to regularly inspect and maintain all components of the drivetrain. This includes checking and replacing worn or damaged belts and pulleys, lubricating moving parts, and ensuring proper alignment of all components.
