Laws in Otto, Diesel, etc. cycles
In summary, the area within the loop on the PV diagram tells you the power output of the engine at a certain rpm.
physea
211
Hello guys,
I am a bit confused. Is it that PV/T=constant for ALL the processes of ALL cycles, like Otto, Diesel, Rankine?
I know that PV=mRT, so does that mean that PV/T=constant all the time?
Secondly, I am a bit confused as I read that PV^γ=constant. What is that exactly? Where does it come from and when does it apply?
Thanks!
It is constant in ideal gas if number of moleculs remains constant.
I know that, I think it was clear when I wrote PV=nRT? (or mRT)
But what is PV^γ=constant, where it comes from, where it applies?
Also, where is the temperature highest in the Otto cycle? I would assume it is where PV is highest, but how can one know?
No, not all the time. Explosions and shock waves don't follow the perfect gas law.
Where does it come from? Statistical Mechanics https://en.wikipedia.org/wiki/Statistical_mechanics
A sufficient (but not necessary) condition for statistical equilibrium with an isolated system is that the probability distribution is a function only of conserved properties (total energy, total particle numbers, etc.).[1] There are many different equilibrium ensembles that can be considered, and only some of them correspond to thermodynamics.[1]Additional postulates are necessary to motivate why the ensemble for a given system should have one form or another.
The key word is equilibrium. Explosions and shock waves are non-equilibrium for brief intervals of time.
No, it wasn't. This question makes that clear.
The ideal gas law is an approximation. Approximations are approximately valid under some circumstances, but there are circumstances where they are very far from valid.
Do a google search for adiabatic process.
OK, I am talking about UNDERGRADUATE PHYSICS, or if you prefer HIGH SCHOOL physics and as I cleared in the begining, Otto, Diesel, Rankine IDEAL cycles.
So PV^γ=constant only in adiabatic processes and this is an ADDITIONAL formula to the PV=constant? So in adiabatic processes both PV and PV^γ are constant?
Also, does anyone know the difference between η(Otto) and η(thermal) as below ?
I don't know what are the definitions of these two efficiencies, I don't know why there are even two efficiencies, it doesn't make sense.
OK, I'll change the prefix on this thread to B if that's more appropriate.
Edit: All your questions can be answered in the Wikipedia article. https://en.wikipedia.org/wiki/Perfect_Gas_Law
Please study that. If there are parts of that you don't understand, then post again.
So was I.
No, ##PV=nRT## would be the additional formula.
No. ##PV## is constant for an isothermal process. ##PV^\gamma## is constant for an adiabatic process.
Where did you find these two expressions for the efficiency?
In an engine cycle what does the area enclosed within the loop on the ##PV## diagram tell you?
What is the general definition of the efficiency of any engine?
I found them in the notes handed to me, they should be equal each other I suppose?
Definition is the net work over heat supplied with net work being q supplied minus q exiting.
Guys,
In ideal Rankine cycle, we say that during the isobaric expansion, Qin = Δh. However, isn't the correct Qin - W = Δh -> Qin - PΔV = Δh?
Something else guys, let's say you know all the P,V,T of a 4 stroke Otto engine. You also know the rpm and the compression ratio.
Are you able to find the power of the engine? I think from Cv and T, you find the Qin and the Qout, thus the Wnet.
But that would be in kJ/kg, so don't you need the mass flow rate to be able to calculate power?
Anyone?
physea said:
Anyone?
Can you please ask each of your questions in separate threads? We feel like we're trying to hit a moving target.
Related to Laws in Otto, Diesel, etc. cycles
1. What is the Otto cycle?
The Otto cycle is a thermodynamic cycle used in spark-ignition internal combustion engines (e.g. gasoline engines). It consists of four processes: intake, compression, power, and exhaust.
2. How does the Diesel cycle differ from the Otto cycle?
The Diesel cycle is similar to the Otto cycle, but it uses a higher compression ratio and does not rely on a spark plug for ignition. Instead, fuel is injected into the cylinder at high pressure, causing it to ignite due to the high temperature of the compressed air.
3. What are the main laws that govern these cycles?
The main laws that govern Otto, Diesel, and other thermodynamic cycles are the first and second laws of thermodynamics. These laws dictate that energy cannot be created or destroyed, but can only be converted from one form to another, and that in any thermodynamic process, the total entropy of a closed system will either remain constant or increase.
4. What is the efficiency of these cycles?
The efficiency of these cycles is limited by the Carnot efficiency, which is based on the difference in temperature between the hot and cold reservoirs of the system. In real-world applications, the efficiency of these cycles is typically around 30-40%, with the rest of the energy being lost as heat.
5. How are these cycles used in practical applications?
Otto and Diesel cycles are used in internal combustion engines, which are commonly used in cars, trucks, and other vehicles for transportation. They are also used in power plants to generate electricity. Other variations of these cycles, such as the Brayton cycle, are used in gas turbines for power generation and aircraft propulsion.
  • Mechanical Engineering
  • Classical Physics
