Laymans time and distance canundrum
  • Thread starter Robin07
  • Tags
    Time
In summary, the conversation discusses the relationship between time and distance when it comes to rotational motion. The concepts of angular velocity and linear velocity are explained, with the understanding that the linear velocity is dependent on the radius of the circle being traveled. This is different from linear motion, where speed is determined by distance over time.
Robin07
139
Hi everyone,
I have often wondered about the time and distance relationship.
Case in point: If you wind a flat coil, let's say six inches in diameter, and cause a current to run though it. The electrons that travel on the outer most perimeter will need to travel a much longer distance to complete one circumference compared to the inner most electrons to complete one distance around. I understand that each electron will travel the same speed but cover a different distance because the wire is of one piece. This alone took me months to understand. This is much like the hands on a clock. It's now obvious, to me, that the inner part of the hour hand will spend the same amount of time completing one revoluation. What is so confusing to me is that, when a person is holding a rope and two objects are attached at different distances away on that rope and then spun so that the stones are now air borne, the objects are read to be traveling at different speeds according to a radar detector? How is this discrepancy justified? For me this is much like walking with the moon as it rotates around our Earth. A traveler would take 24hrs. to complete one trip around our planet, which would be X amount of time over the distance but the moon also travels within the same time frame. Would the moon be traveling the same speed as the traveler on Earth? I would say not.
Thanks for all your input
Note that all your examples involve rotational motion of some sort.
When talking about rotations, we discern two velocities: the angular velocity (usually denoted [itex]\omega[/itex] - small omega, some people just write w) and linear velocity (usually denoted v).
The angular velocity tells you how fast something rotates, it is measured in angle per time (degrees/second or radians/second). For example, if omega = 12 degrees/second, it would take the object 30 seconds to get back where it started (do a complete revolution).
The linear velocity is something the velocity at which an object would be released, if you would release the constraint. For example, if you put a stone on a rotating circular platform and suddenly stop the platform, the stone will fly off tangent to the platform with linear velocity.
The angular and linear velocity are related by
[tex]v = \omega r[/tex]
where r (radius) is the distance from the center of rotation to the object. So if I put two stones on my round platform, one near the inside and one at the edge, they will necessarily have the same angular velocity (they rotate with the platform). However, the one with the smaller radius will have a smaller linear velocity; basically: it has to cover less distance in one revolution than the other stone does. (Of course, this is simply a consequence of the fact that the circumference of the circle which they travel is 2*pi*r).
It's a lot to think about probably, but does it clarify a bit?
Thanks, yes it's abit clearer.
You mentioned that "the one with the smaller radius will have a smaller linear velocity; basically: it has to cover less distance in one revolution than the other stone does. (Of course, this is simply a consequence of the fact that the circumference of the circle which they travel is 2*pi*r)."
So from my understanding than, 'Time over distance' does determine speed if your calculating the objects speed in a straight line but when it come to a circular path the angular and linear velocity must be concidered to determine the actual speed.
Exactly. The linear velocity is distance / time (not the other way around, as you said below). So v = 2 pi r / t. The angular velocity is number of radians / time (360 degrees = 2 pi radians in x units of time means covering 2 pi / x radians in one unit of time). So omega = 2 pi / t. Then automatically, v = omega r.
Indeed. Note that you can actually consider v as the "real" velocity, and omega more as a tool. Newtons second law ("F = m a") tells you that, in absence of force, objects move in a straight line at constant velocity. When an object is constrained to move in a circle, it must undergo a force (for example, friction with the rotating platform or tension in the cable it is tied to), which accelerates it inward so the velocity is always along the circle. As soon as you would lift this force (cut the rope, for example) the force would be zero, the acceleration would be zero and the object would fly on with the velocity it has at that particular moment: velocity v in the direction perpendicular to the radius of the circle, so to speak. What the constant angular velocity expresses is just that, although the linear velocity changes all the time (in direction, not in magnitude), it just changes in such a way as to keep the object going around the circle at a steady rate.
Related to Laymans time and distance canundrum
What is the "Laymans time and distance conundrum"?
The "Laymans time and distance conundrum" is a term used to describe the common confusion or misunderstanding about the relationship between time and distance in everyday situations. It often results in people making incorrect assumptions or estimations about how long it will take to travel a certain distance.
What are some common examples of the "Laymans time and distance conundrum"?
Some common examples include underestimating the time it will take to arrive at a destination because of not factoring in traffic or delays, assuming that a shorter distance automatically means a shorter travel time, and miscalculating the speed needed to reach a certain distance in a specific amount of time.
Why is it important to understand the concept behind the "Laymans time and distance conundrum"?
Understanding the concept behind the "Laymans time and distance conundrum" can help people make more accurate plans and estimates for travel time. It can also prevent frustration and disappointment when things take longer than expected.
How can the "Laymans time and distance conundrum" be explained scientifically?
Scientifically, time and distance are directly related to each other through the concept of speed. Speed is defined as the distance traveled in a specific amount of time. Therefore, the time it takes to travel a certain distance is dependent on the speed at which the distance is covered.
What are some tips for avoiding falling into the "Laymans time and distance conundrum" trap?
To avoid falling into the "Laymans time and distance conundrum" trap, it is important to consider all factors that may affect travel time, such as traffic, weather, and mode of transportation. It can also be helpful to use tools or apps that calculate travel time based on current conditions. Additionally, understanding the concept of speed and how it relates to time and distance can aid in making more accurate estimations.
  • Mechanical Engineering
