MHB Layout Notation for matrix calculus
Dethrone
Hi,
I guess this could be a rather silly question, but I got a bit confused about the "numerator layout notation" and "denominator layout notation" when working with matrix differentiation: ="http://https://en.wikipedia.org/w...a.org/wiki/Matrix_calculus#Layout_conventions
It says that with the denominator layout notation, we interpret differentiation of a scalar with respect to a vector as such: $\frac{\mathrm{d}L}{\mathrm{d}w_1}=[\frac{\mathrm{d}L}{\mathrm{d}w_{11}}\frac{\mathrm{d}L}{\mathrm{d}w_{12}} ... \frac{\mathrm{d}L}{\mathrm{d}w_{1n}}]^T$, $L$ a scalar and $w_1$ an $n$ x $1$ vector.
But what if we represent the scalar $L$ differently? e.g $L=w^Tx$, where $w$, $x \in \Bbb{R}^{n \times1}$.
Then we get $\frac{\mathrm{d}L}{\mathrm{d}w}=\frac{\mathrm{d}(w^Tx)}{\mathrm{d}w}=\frac{\mathrm{d}(x^Tw)}{\mathrm{d}w}=x^T$, which is a $1$ by $n$ vector. Doesn't this result disagree with the denominator layout notation? I read somewhere on the wiki that says one should stick to one type of notation, but if certain types of calculations favors one type of notation over the other, wouldn't that be problematic or confusing?
I came across this when trying to calculate $\frac{\mathrm{d}L}{\mathrm{d}W}=[\frac{\mathrm{d}L}{\mathrm{d}w_1}\frac{\mathrm{d}L}{\mathrm{d}w_2}...\frac{\mathrm{d}L}{\mathrm{d}w_c}]$, where $W$ is $n$ by $c$, and each $\frac{\mathrm{d}L}{\mathrm{d}w_i}$ is the derivative of $L$ with respect to the column vector $w_i$. As you can see fairly quickly, I started off with what wiki calls the the "denominator layout notation" but since each $\frac{\mathrm{d}L}{\mathrm{d}w_i}$'s ended up being $1$ by $n$, it didn't make much sense. Basically what I'm trying to say is that writing the scalar $L$ as $w^Tx$ caused my result to use numerator notation, but since I started off using denominator notation my answer gets messed up.
Hey Rido12! (Smile)
Indeed, the matrix layouts of derivatives tend to be confusing.
The problem as I see it, is that the matrix layout is an arbitrary representation.
And it already more or less fails if we have more than 2 dimensions, since then we can't properly represent it in a rectangular matrix.
When we take the derivative of a vector function with respect to a vector, what we actually have is a set of scalar functions:
$$\pd {\mathbf f}{\mathbf x} = \left(\pd {f_i}{x_j}\right)$$
That is, forget about the matrix layout.
And when we want to multiply it with a vector $\mathbf v$ to find a directional derivative, which is really an application of the chain rule, what we need to do is:
$$\pd {\mathbf f}{\mathbf x} \cdot \mathbf v = \sum_{i=1}^n \pd {f_i}{x_j} v_j \mathbf e_i$$
where $\mathbf e_i$ is the $i$-th unit vector.
Since as humans we like to represent that in something we can write down, and that fits into how we usually do matrix manipulations, the most natural way that fits in our conventions is:
$$\begin{bmatrix}\pd {f_1}{x_1} & ... & \pd {f_1}{x_n} \\ \vdots & & \vdots \\ \pd {f_n}{x_1} & ... & \pd {f_n}{x_n} \end{bmatrix}
\begin{bmatrix}v_1 \\ \vdots \\ v_n\end{bmatrix}$$
This is the Jacobian form, or numerator layout.
The thing to realize, is that whenever we do something like this, we need to ensure that the elements get multiplied and summed with the right elements.
So if we choose to pick the denominator layout instead, to ensure our conventional matrix product works out, we need to write it as:
$$\begin{bmatrix}v_1 & \dots & v_n\end{bmatrix}\begin{bmatrix}\pd {f_1}{x_1} & ... & \pd {f_n}{x_1} \\ \vdots & & \vdots \\ \pd {f_1}{x_n} & ... & \pd {f_n}{x_n} \end{bmatrix}
Or we can choose to forget about conventional matrix layouts and products, and just write:
$$\sum_{i=1}^n \pd {f_i}{x_j} v_j \mathbf e_i$$
or for short:
$$\pd {f_i}{x_j} v_j$$
following Einstein summation convention.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
