LC circuits in series with Diodes
In summary: No, it will be a continuous re-distribution of the charge. As soon as each diode starts to be forward-biased, it will conduct current in the forward direction.Instead, look at "switched capacitor" circuits, which use transistor switches to transfer charge between discrete capacitors (used in voltage boosting, or in signal processing, or in image processing, etc.).Is this what you mean by continuous re-distribution of the charge?I found this video this morning. Particularly at 3 minutes in, it describes a signal reflecting because of differences in inductance. I'm wondering if using diodes would mimic this reflection by having a higher inductance in one direction. Im
Samson4
245
I need help understanding what will happen when the switch in closed in this circuit.
What I want to happen is for Cap B to charge first and then discharge into Cap C.
When the charged capacitor begins to discharge, will it charge Caps B and C at the same time? It will have to overcome the impedance of both Inductors to do so.
<< Mentor Note -- Schematic has been updated, please see the discussion below >>
https://www.physicsforums.com/attachments/221453
You show only the left cap as charged, so when you close the switch, not much happens (other than the reverse I_s currents flowing through the diodes)...
Unless the left cap has a negative charge value?
Likes Averagesupernova and Samson4
You mean the charged capacitor won't charge either capacitor? Why is that? Assume the first capacitor is charged correctly for the current to flow through the diode while discharging. The other capacitors are not charged before the switch is closed.
So you posted the schematic upside-down? The convention for most schematics is for the more positive voltages to be near the top of the schematic...
Can you show us the differential equations for the KCL or KVL analysis? That's the right way to approach this after the circuit is inverted...
Likes Samson4
I apologize, I never learned these methods. I have searched them and after a little reading I'll report back.
However; I have corrected the diodes in the schematic.
Likes berkeman
Have you learned Calculus yet? If not, we can try to offer a simplified explanation (with less accurate results).
Do you have an application in mind, BTW?
Likes Samson4
I have yet to learn calculus. As for the accuracy; I just need to know if the capacitors will charge simultaneously or one after the other.
As for the application, I am going to make this very circuit but with connections and diodes that return from the last capacitor to the first. I want to do some experiments with this setup. If the capacitors won't charge 1 by 1 then it won't be useful.
Likes Samson4
Im still re-watching it to try and figure out how diodes would effect this. Also wondering how a sparkgap would effect the circuit if it replaces the switch and adding high frequency ac at the resonant frequency of each section of the schematic.
Oh, you are looking into transmission lines? That's different.
Diodes in a transmission line will make it lossy, which is usually a bad thing. Can you just please say what you are wanting to do? That will make this go a lot faster... Thanks.
Sort of like a transmission line I guess. I want the capacitor of an lc circuit to discharge into another lc circuit with identical capacitance and inductance. When the second capacitor charges I want it to discharge into another lc circuit and that one to discharge into the original lc circuit.
The schematic will be standalone. It won't be used to power anything.
If I power it with an ac signal at the resonant frequency of each lc segment, will this satisfy my needs?
Not without some switching as @berkeman said.
But I wonder why you care if they charge sequentially or not. Why? What are you trying to accomplish?
Are you thinking of something like this? https://en.wikipedia.org/wiki/Voltage_doubler
Likes Samson4
If this is a circuit made of discrete components it will quickly settle to an equilibrium state. I think you need switching and amplifying elements between the stages.
Likes Samson4
I like the idea that the energy is moving in one direction at all times. This is only possible if they charge sequentially. I could do this with electromagnetic waves but the wave lengths will be huge or the radiation is problematic.
That's 3 times I've been told I'll need switching. Back to the drawing board.
Wouldn't equilibrium mean that all capacitors are discharged?
Energy can split and flow in two branches in parallel. It's like the water in a river going around both sides of an island. I think you need a course on basic circuits because you are confusing yourself with some incorrect concepts.
I suggest you try and simulate it.
If the first capacitor was replaced with a DC voltage source then the following caps would end up at a slightly lower voltage due to the diode drops and other losses. However it's not a voltage source, the source voltage will be falling as the current through the first inductor increases.
Exactly what happens will depend on the various time constants. It's likely the caps will end up with some DC voltage but that may leak away rapidly through the (non-ideal) capacitors.
It sounds like you are trying to build something like a ring oscillator? Bucket brigade device? Delay line?
Likes Samson4
What do you mean? If I'm standing on that island all the energy is moving in the same direction.
Thank you for those terms. I'll have to search them these evening when I get off.
Have you thought of trying neon bulbs instead of the diodes?
If I'm showing my age too much, perhaps diacs would behave similarly. (Though I haven't seen one of those for decades either! Perhaps there is a modern equivalent.)
Not really sure what that will achieve. At every stage there are losses in the diode and resistance of the inductor so any energy that starts in the first capacitor will rapidly be lost as heat. The energy won't keep going round and round if that's what you were hoping for.
Likes Samson4
I understand using the diac for the switch; but, why use the neon bulbs instead of diodes? I was contemplating a sparkgap for the switch so the diac is actually more modern than what I had planned.
I'm not expecting perpetual motion but I am expecting to measure the resistance around the circuit and use ohms law to estimate how many times around the circuit the current will flow.
Diac or neon bulb is like the spark gap which will work at lower voltage. A neon bulb breaks down at about 100 V, a diac lower at about 30 V.
If I understand your intention, the first capacitor would be charged well above breakdown voltage. When the switch is closed, the first device would break down and conduct, charging up the second capacitor. When this capacitor reached the breakdown voltage, the next device would start to conduct and charge up the third capacitor.
In principle I suppose this could be extended to further stages, though with the neons there would be a large voltage drop at each stage due to the sustain voltage. Probably the diacs would be better in that respect. You might need to add resistances (or maybe inductors) to limit the peak currents.
Likes Samson4
Here is an LTspice simulation of the response of a lumped LC transmission line with series diodes. Initial C1 = 12 volts, all other capacitors zero volts. Notice how the energy is transferred from C1 at the start to C7 at the end of the line. Diodes prevent reverse flow but causes losses.
LTspice circuit.asc and plot.plt files attached, remove the .txt extension to run.
  • TL-1.asc.txt
  • TL-1.plt.txt
Likes berkeman, Samson4 and Merlin3189
Since that simulation worked with a switch, here is one that uses a trigger pulse and recirculates the wave.
Here is the lumped transmission line that includes diodes and a feedback link. Less stages can be used.
The short rectangular pulse is used to insert the initial wave energy, that pulse is then turned off and the sine wave allowed to recirculate.
The wave voltage has been increased to dominate the diode voltage and so reduce attenuation with time.
Notice that the diodes force the wave to circulate in the forward direction only.
LTspice files attached, remove the .txt extensions to run.
  • TL-Zo-6 loop.plt.txt
  • TL-Zo-6 loop.asc.txt
Likes berkeman and Samson4
I found this on wiki about Grain-Oriented electrical steel:
" The magnetic flux density is increased by 30% in the coil rolling direction, although its magnetic saturation is decreased by 5%. It is used for the cores of power and distribution transformers, cold-rolled grain-oriented steel is often abbreviated to CRGO."
My thinking is that a transformer core made with the laminations oriented in the same direction would have an asymmetrical inductance. In your last circuit, replacing the diodes with such inductors would restrict the current in 1 direction linearly in respect to the increased inductance in that direction. CRGO cores are obviously not good enough for this use because the asymmetry is not pronounced enough. However, my point is that it is possible. I have no idea if such components exist already. I have had no luck in finding them if they do. I did sketch one up though. Maybe something like this would work:
The high inductance coil behaves like a toroid. It's ends are closer together than the low inductance coil. Shouldn't this mean more magnetic energy can be stored in it's field? If it was designed to have 10 times the inductance in one direction than the other; it should be capable of replacing the diodes in the circuit.
Does this sound correct or like nonsense?
@ Samson4.
What are you really trying to do here? It seems like you need complexity beyond understanding.
I do not think you will be able to replace the diodes by using saturable core inductors with a fixed magnetic bias. Saturable cores and magnetic amplifiers were in vogue in the 1930s and 1940s. They will add to the complexity rather than reduce it.
Baluncore said:
@ Samson4.
Those were not saturable cores. They are permanent magnets that allow the magnetic field of the coil to terminate on it's poles; or circle around the exterior of the coil.
@Samson4 -- Please let us know what you are trying to accomplish.
  • #31
I want an apparatus that I can experiment with. I am most interested in; the wave nature the capacitors will charge with, the momentum of the moving charges, thermal coefficient of resistance. Basically, an analog of em waves that have acceptable wavelength without producing harmful radiation. It is ideal if I can keep the time between input pulses long.
Likes berkeman
Related to LC circuits in series with Diodes
1. What is an LC circuit in series with diodes?
An LC circuit is a type of electrical circuit that consists of an inductor (L) and a capacitor (C) connected in series. The addition of diodes to this circuit allows for the control of current flow and can be used for a variety of applications such as filtering and voltage regulation.
2. How does an LC circuit in series with diodes work?
An LC circuit in series with diodes works by using the inductor and capacitor to store energy in the form of an oscillating current. The diodes then control the flow of this current, allowing it to pass through in one direction while blocking it in the other. This results in a smooth and regulated output.
3. What are the advantages of using an LC circuit in series with diodes?
One of the main advantages of using an LC circuit in series with diodes is its ability to filter out unwanted frequencies in a circuit. This can be useful for reducing noise and interference. Additionally, the use of diodes allows for control of the current, making it a versatile circuit for various applications.
4. What are some common uses of LC circuits in series with diodes?
LC circuits in series with diodes are commonly used in power supplies, voltage regulators, and radio frequency (RF) circuits. They can also be found in electronic devices such as televisions, radios, and computers.
5. How do I calculate the values for an LC circuit in series with diodes?
The values for an LC circuit in series with diodes can be calculated using the following equations:
- For the resonant frequency: f = 1 / (2π√LC)
- For the inductive reactance: XL = 2πfL
- For the capacitive reactance: XC = 1 / (2πfC)
Once these values are calculated, they can be used to determine the appropriate values for the inductor and capacitor in the circuit.
  • Electrical Engineering
  • Classical Physics
