LC oscillator - is it quantised?
In summary, the discussion is about whether a LC oscillator is quantized and how a transistor amplifier affects this quantization. It is mentioned that a pure LC oscillator can be quantized using coherent states, but once losses and a transistor amplifier are introduced, it becomes an interacting system. The calculation is done for a 100 MHz oscillator and it is found that thermal noise is much larger than the lowest quantum. The question then arises of whether transistors can be analyzed in a quantum manner and suggestions are given to look at the quantum description of a laser amplifier. However, it is noted that this is a difficult task and could potentially lead to a "crackpot theory." The role of the transistor in maintaining the energy of the LC circuit
Confused2
If yes and the oscillation is maintained by a transistor then what is the transistor amplifying?
I would say that a pure LC oscillator is quantized, in the sense that it has stationary states and so on (but probably, the best description is using coherent states). However, from the moment you have losses and a transistor amplifier, this becomes an interacting system. You can try to treat it perturbatively if the losses (= interactions) are weak.
Now, as an exercise, you should calculate what are the classical amplitudes corresponding to a particular LC, say, with a frequency of 100 MHz. You'll find them to be VERY VERY small. I would guess that thermal noise is already much much bigger.
Let's do the calculation:
the energy quantum of a 100 MHz oscillator is h x nu ~ 6.6 10^(-26) J
On a 1pF capacitor, for instance, that corresponds to (E = C V^2/2)
0.36 microvolt. So the ground state of this oscillator will be such that the maximum voltage on the capacitor equals 0.36 microvolt.
Now, the thermal energy that should be present in this oscillator, at room temperature, is 1/2 kT = 0.5 1.38 10^(-23) 300 = 2.1 10^(-21) J, which is already much higher than the lowest quantum. Even at liquid helium temperature (4K) we have 2.7 10^(-23) J of thermal noise. It corresponds to 7.5 microvolts of thermal noise on the 1 pF capacitor.
So the quantization of "classical" electronic circuits is usually completely swamped by thermal noise considerations.
Hi Vanesch ..
Many many thanks. The overall 'drift' of this question is in the direction of analysing a transmitter at (say) 100Mhz entirely in terms of quantum theory.. from transmitter to receiver. I fear this is as much an exercise in what is 'acceptable' as it is in theory.
Having accepted the initial premise as far as the LC.:smile: .
Would it be fair to say that the transistor is now making good lost photons ( energy approx 6.6 10^-26 J) .. transistors aren't normally analysed in this way .. any thoughts or pointers as to where such an analysis might be found, please..?
-C2.
Yes, that's a way to see it. But what you attempt to do is damn difficult! Wouldn't really know where to start, myself.
-C2.
I think the closest you can come, is the quantum description of a laser amplifier, if you consider your transistor amplifier as a coherent stimulated emitter. Look up the "bible" of Mandl and Wolf for that, on quantum optics. However, I think that the quantum-optical setting is "simpler" than your transistor! Nevertheless, you could find inspiration to write down a phenomenological quantum model of your circuit by looking at how a laser amplifier works.
Many thanks vanesch, both for your wise comment and suggestion.. I agree it looks laserish .. but if transistors work that way in this circuit then they should always work that way..
This has the potential to be a trip into my own private Crackpot Theoryland. A little handwaving would be most welcome (preferably not of the good-bye type)..
My own hand waving explanation looks rather like drowning. Clearly we maintain the total energy of the LC circuit at a level far above thermal noise.. but how does the transistor know that's what we want it to do? I've always treated transistors as a current driven device and they have always responded well to this type of treatment.. holes, bandgaps etc. . I've never seen one fed with a quant.. I can't even imagine how to get one in there, let alone get more out.
The appearance (waves hands wildly) is that it will not be possible to treat the transistor 'in isolation'..
Hand waving most welcome..
FAQ: LC oscillator - is it quantised?
What is an LC oscillator?
An LC oscillator is an electronic circuit that uses an inductor (L) and a capacitor (C) to generate a continuous oscillation of current or voltage. It is commonly used in radio frequency (RF) and audio frequency (AF) applications.
How does an LC oscillator work?
An LC oscillator works by constantly charging and discharging the capacitor through the inductor. The inductor stores energy in the form of a magnetic field, while the capacitor stores energy in the form of an electric field. As the energy oscillates between the two components, an alternating current or voltage is produced.
Is an LC oscillator quantized?
Yes, an LC oscillator is quantized. This means that the energy levels within the oscillator are limited to discrete values, rather than being continuous. This is due to the discrete nature of the electron energy levels in the inductor and capacitor.
How is the quantization of an LC oscillator determined?
The quantization of an LC oscillator is determined by the energy levels of the electrons in the inductor and capacitor. These energy levels are determined by the physical properties of the components, such as their size, shape, and material. The quantization also depends on the external factors such as temperature and external magnetic fields.
What are the practical implications of the quantization of an LC oscillator?
The quantization of an LC oscillator has implications on its performance and design. It can limit the range of frequencies that the oscillator can produce and can also introduce noise and instability. Therefore, it is important to carefully design and select the components of an LC oscillator to ensure optimal performance.
