LCC 205 8.4.7 sine substitution (definite integral)
In summary, you can use the inverse sine of each value in the compound inequality to get the correct limits of integration.
karush
MHB
3,269
$\tiny{LCC \ \ 205 \ \ \ 8.4.7 \ \ sine \ \ substitution }$
$\displaystyle
I=\int_0^{5/2} \frac{1}{\sqrt{25-x^2}}\ dx
=\frac{\pi}{6}
$$\displaystyle
x=5\sin\left({u}\right) \ \ \ dx=5\cos\left({u}\right) \ \ du
$$\displaystyle
I=\int_0^{5/2}
\frac{1}{\sqrt{25-25 \sin^2 \left({u}\right)}}
\ \ 5\cos\left({u}\right)
\ du $$
Not sure if this setup is right
I edited the thread title to be a little easier on the eyes...
You are using a good substitution, but you need to change your limits of integration in accordance with your substitution, so that you have $u$-values there instead of $x$. :)
So if
$\displaystyle 0=5\sin\left({a}\right) \ \ \ a=\pi$
$\displaystyle \frac{5}{2}=5\sin\left({b}\right)\ \ \ b=\frac{7\pi}{6}$
Then
$$\displaystyle
I=\int_a^b
\frac{5\cos\left({u}\right)}{\sqrt{25-25 \sin^2 \left({u}\right)}}
\ \ du
\implies \int_a^b
\frac{5\cos\left({u}\right)}{5\sqrt{1- \sin^2 \left({u}\right)}}
\ \ du
\implies \int_a^b 1 \ \ du
$I=\left[u\right]_a^b
= \frac{7\pi}{6}-\frac{6\pi}{6}
=\frac{\pi}{6}$
Hopefully 🐮🐮🐮🐮
Note that:
\(\displaystyle \sin\left(\frac{7\pi}{6}\right)=-\frac{1}{2}\)
You have:
\(\displaystyle u(x)=\arcsin\left(\frac{x}{5}\right)\)
Now, observe that:
\(\displaystyle 0\le x\le\frac{5}{2}\)
Hence:
\(\displaystyle 0\le \frac{x}{5}\le\frac{1}{2}\)
Can you now get the correct limits of integration?
How would that be in terms of u?
$\frac{\pi}{6}$
Is the correct answer😯
If we take the inverse sine of each value in the compound inequality, we get:
\(\displaystyle \arcsin(0)\le \arcsin\left(\frac{x}{5}\right)\le\arcsin\left(\frac{1}{2}\right)\)
Now simplify...:)
$$0\le\arcsin\left({\frac{x}{5}}\right)\le \frac{\pi}{6}$$
Why would this help
Why would this help
Because:
\(\displaystyle u(x)=\arcsin\left({\frac{x}{5}}\right)\)
And so we have:
\(\displaystyle 0\le u\le\frac{\pi}{6}\)
And the integral then becomes:
\(\displaystyle I=\int_0^{\frac{\pi}{6}}\,du=\frac{\pi}{6}\)
OK got it🐮
Thanks for not giving up on me
The help here is awesome
FAQ: LCC 205 8.4.7 sine substitution (definite integral)
What is LCC 205 8.4.7?
LCC 205 8.4.7 is a specific topic in the field of mathematics, specifically in calculus. It refers to a particular method of solving definite integrals using sine substitution.
What is sine substitution?
Sine substitution is a technique used to solve definite integrals that involve expressions containing both a square root and a quadratic term. It involves substituting the variable with a trigonometric function, specifically sine, in order to simplify the integral and make it easier to solve.
How is sine substitution used in definite integrals?
Sine substitution is used by substituting the variable in the integral with a trigonometric function, specifically sine. This substitution can then be used to simplify the integral and make it easier to solve. After solving the integral with the substituted variable, the result is then converted back to the original variable to get the final answer.
What are the advantages of using sine substitution in definite integrals?
There are a few advantages of using sine substitution in definite integrals. It can simplify the integral and make it easier to solve, it can help to avoid complex algebraic manipulations, and it can also be used to solve integrals that may not have a straightforward solution using other methods.
Are there any limitations to using sine substitution in definite integrals?
While sine substitution can be a useful method for solving definite integrals, it may not always be the most efficient or effective method. It may not work for all integrals and may require additional steps or manipulations to get to the final answer. It is important to understand other integration techniques in order to choose the most appropriate method for a given integral.
