prasadini
- 9
The Lowest Common Multiple of 22x32x4 and 23x3
greg1313 said:Do you have any ideas on how this problem may be approached?
prasadini said:There is 2 answer
(a) 144 (e) 24 𝑋 32 How can i get this answer
prasadini said:The Lowest Common Multiple of 22x32x4 and 23x3
The LCM (Least Common Multiple) of two or more numbers is the smallest number that is a multiple of all of them. In this case, the LCM of 22x32x4 and 23x3 is 22x32x4x23, which equals 2112.
To find the LCM of two numbers, you can use the prime factorization method. First, write each number as a product of its prime factors. Then, identify all the common prime factors and the highest power of each one. Finally, multiply all the common prime factors with their highest powers to get the LCM.
The LCM is important in mathematics because it helps us find the smallest number that is a multiple of two or more numbers, which is useful in solving problems involving fractions, ratios, and proportions. It is also used in simplifying algebraic expressions and finding the common denominator in adding or subtracting fractions.
No, the LCM of two numbers cannot be smaller than either of the numbers. This is because the LCM is the smallest number that is a multiple of both numbers, so it must be greater than or equal to both numbers.
If one of the numbers is a multiple of the other, then the LCM is simply the larger number. For example, if one number is 6 and the other is 12, the LCM is 12. This is because 12 is already a multiple of 6, so it is the smallest number that is a multiple of both numbers.
