LDR: Why is conductance proportional to log(intensity)?
In summary, the Weber-Fechner law states that the perceived intensity of a stimulus is proportional to the logarithm of the actual intensity. This is applicable in LDRs, where the resistance changes in response to changes in light intensity. The mathematical reasoning behind this lies in the logarithmic function, which produces a smaller change in value compared to the linear function. While generally applicable to LDRs, the exact relationship may vary. This relationship is used in various industries and is essential in the design and use of LDRs in different applications.
Beam me down
47
I am doing a experimental report on various solid state devices and have come unstuck on my work with LDRs. I have data relating conductance of a CdS photo-resistor to intensity of (white) light. The problem is that I am completely unsure as to why there is a log relationship, as has been suggested to me. I understand why there is an increase in conductivity (hence decrease in resistance), as there are more electrons in the conduction band.
Any hints you can provide would be greatly appreciated,.
Cheers,
Matthew
The log relationship between the conductance of a CdS photo-resistor and intensity of light can be explained by the photoelectric effect. The photoelectric effect occurs when photons are absorbed by an electron in a material, which then causes the electron to become energized and move to a higher energy level, or conduction band. As the intensity of light increases, more photons are absorbed, thus more electrons become energized and move to the conduction band. Since the conduction band has a higher density of electrons, the overall conductivity of the material increases, resulting in the log relationship between conductance and light intensity.
The relationship between conductance and intensity in LDRs can be explained by the physics of semiconductors. LDRs, or light dependent resistors, are made of a semiconductor material such as cadmium sulfide (CdS). In semiconductors, the number of free charge carriers (electrons or holes) in the conduction band is directly related to the intensity of light that falls on the material.
As the intensity of light increases, more photons are absorbed by the semiconductor material, causing more electrons to be excited from the valence band to the conduction band. This results in an increase in the number of free charge carriers, leading to higher conductance.
The reason for the logarithmic relationship between conductance and intensity is due to the bandgap energy of the semiconductor material. The bandgap is the energy difference between the valence band and the conduction band, and it determines the amount of energy required for an electron to move from the valence band to the conduction band.
In semiconductors like CdS, the bandgap is relatively small. This means that even a small increase in the intensity of light can excite a large number of electrons from the valence band to the conduction band, resulting in a large increase in conductance. However, as the intensity of light continues to increase, the number of electrons in the conduction band reaches a saturation point, where the bandgap energy becomes a limiting factor for further excitation. This leads to a logarithmic relationship between conductance and intensity, as the increase in conductance becomes less significant with each subsequent increase in light intensity.
I hope this explanation helps you understand the relationship between conductance and intensity in LDRs. Please let me know if you have any further questions or need clarification on any of the concepts. Keep up the good work with your experimental report!
Related to LDR: Why is conductance proportional to log(intensity)?
1. Why is conductance proportional to log(intensity)?
The relationship between conductance and log(intensity) is known as the Weber-Fechner law, which states that the perceived intensity of a stimulus is proportional to the logarithm of the actual intensity. This means that as the intensity of a stimulus increases, the perceived change in intensity decreases. This relationship has been observed in various sensory systems, including vision and hearing.
2. How is this relationship applicable in LDRs?
In LDRs (light-dependent resistors), the resistance of the material changes in response to changes in light intensity. This change in resistance is directly proportional to the intensity of light, but due to the Weber-Fechner law, the perceived change in intensity will be smaller. Therefore, the resistance of the LDR will be more sensitive to changes in log(intensity) rather than linear intensity.
3. Can you explain the mathematical reasoning behind this relationship?
The mathematical reasoning behind this relationship lies in the logarithmic function. As the intensity of a stimulus increases, the logarithmic function will produce a smaller change in value compared to the linear function. This is why conductance, which is inversely proportional to resistance, is proportional to log(intensity) in LDRs.
4. Does this relationship hold true for all LDRs?
While the Weber-Fechner law and the resulting relationship between conductance and log(intensity) are generally applicable to LDRs, the exact relationship may vary depending on the specific materials and design of the LDR. Other factors such as temperature and wavelength of light can also affect the relationship between conductance and log(intensity).
5. Are there any practical applications of this relationship?
Yes, this relationship is widely used in industries such as photography, where light meters use LDRs to measure the intensity of light. It is also used in automatic lighting systems, solar panels, and other light-sensitive devices. Understanding this relationship is essential in the design and use of LDRs in various applications.
  • Electromagnetism
31K
  • STEM Academic Advising
10K
  • Atomic and Condensed Matter
9K
