Lead Acid Battery Flyback Pulses: Electrolyte Decomposition
In summary, the conversation discusses the use of inductively generated flyback pulses to potentially recondition old lead acid batteries by breaking up sulfate deposits. However, there is a question about the effectiveness of these pulses due to the low impedance of the pulse-producing coil and the battery itself. The conversation also mentions the need for reputable sources to support claims about the use of pulses for battery reconditioning.
JulesP
TL;DR Summary
Plausibility of electrolyte decomposition using Flyback pulses
Can inductively generated flyback pulses (~1kV) cause the decomposition or ‘consumption’ of any components in the electrolyte of a lead acid battery resulting in an energy release?
Chemistry news on Phys.org
Only in part. While pulses can apparently be used to break up Sulphate deposits, I have also heard that the voltage of pulses, once they meet the battery, is effectively grounded due to the low impedance of the pulse-producing coil and the battery itself. As such they are no longer in a position to effect any significant changes to the electrolyte at a chemical level. What do you think?
JulesP said:
I have also heard
At PF, we require links to reputable sources for this. "I have heard" is generally not good in the technical forums. Thanks :smile:
It was a personal comment from a fellow researcher. So I am not in a position to reference it. . . .
Perhaps a Google or Google Scholar search could provide some backup for the comment? :smile:
FAQ: Lead Acid Battery Flyback Pulses: Electrolyte Decomposition
What are flyback pulses in the context of lead acid batteries?
Flyback pulses refer to the high-voltage spikes generated when an inductive load, such as a transformer or inductor, is suddenly switched off. In the context of lead acid batteries, these pulses can occur during the charging process, especially in systems using inductive components for voltage regulation or current limiting.
How do flyback pulses affect the electrolyte in lead acid batteries?
Flyback pulses can lead to the decomposition of the electrolyte in lead acid batteries. The high-voltage spikes can cause electrolysis of the water in the electrolyte, producing hydrogen and oxygen gases. This gas evolution can reduce the efficiency of the battery, increase maintenance requirements, and potentially lead to safety hazards due to gas accumulation.
What are the signs of electrolyte decomposition due to flyback pulses?
Signs of electrolyte decomposition due to flyback pulses include increased gassing (bubbling) within the battery, a decrease in electrolyte levels, and changes in the specific gravity of the electrolyte. Additionally, the battery may exhibit reduced capacity, higher internal resistance, and shorter overall lifespan.
How can the negative effects of flyback pulses on lead acid batteries be mitigated?
To mitigate the negative effects of flyback pulses on lead acid batteries, it is essential to use proper circuit design and protective components. This can include using flyback diodes to clamp the voltage spikes, snubber circuits to absorb excess energy, and ensuring that the charging system is well-regulated to prevent excessive voltage fluctuations. Regular maintenance and monitoring of the battery can also help identify and address issues early.
Are there any specific charging techniques that can minimize electrolyte decomposition in lead acid batteries?
Yes, there are specific charging techniques that can minimize electrolyte decomposition in lead acid batteries. Using a multi-stage charging process, such as a three-stage charger (bulk, absorption, and float), can help regulate the voltage and current more effectively. Pulse charging with controlled pulse width and frequency can also reduce the likelihood of generating harmful flyback pulses. Additionally, temperature compensation during charging can help prevent overcharging and excessive gassing.
