flyusx
- 43
- 1
- Homework Statement
- A spacecraft measuring 8 m by 3 m by 3 m is struck by space junk leaving a circular hole of radius 4 mm. About how much time is left to patch the leak? Assume an ideal gas and STP (1 mol of atoms occupies 22.4 L).
- Relevant Equations
- Leakage: $$\frac{NA\bar{v}}{4V}$$
Boltzmann Distribution: $$\Pr(v)=4\pi\left(\frac{m}{2\pi k_{B}T}\right)^{\frac{3}{2}}v^{2}\exp\left(-\frac{mv^{2}}{2k_{B}T}\right)$$
The leakage equation is pretty straightforward to use once I found the average velocity: N is the number of atoms, A is the area of the hole, v-bar is the average velocity and V is the volume of the container.
To find the average velocity, I used the Boltzmann distribution. I set the temperature be 273.15 K. For mass, I used $$\frac{28.96 g}{1 mol}\frac{1 mol}{N_A atoms}\frac{1 kg}{1000 g}=\frac{4.808921063\cdot10^{-26} kg}{atom}$$I then used the Boltzmann distribution to find the average velocity by taking $$\frac{\int_{0}^{10000}v\Pr(v)\text{d}v}{\int_{0}^{10000}\Pr(v)\text{d}v}=446.8783872 m/s$$From the leakage formula, I just took the area of the hole to be $$A=\pi r^{2}=\pi\left(4\cdot10^{-3}\right)^{2}$$, N to be the number of atoms in a mol and V to be the volume of the container (multiplied by ##10^{-3}## to convert to cubic metres). This returned a leakage rate of ##1.509739807\cdot10^{23}## atoms per second.
To find the number of atoms in the spaceship, I used 1.293 kg/m^3 as the average density of air. $$\frac{1.293 kg}{m^{3}}72m^{3}\frac{28.96 g}{1 mol}\frac{1 mol}{N_A atoms}\frac{1 kg}{1000 g}=1.935902021\cdot10^{27}\text{ atoms}$$Dividing the total number of atoms by the leakage rate returns 213.7 minutes (over 3 hours). The textbook says the correct answer is about 2 hours.
What am I doing wrong?
