Courses Learning Parallel Computation as a particle physicist
Investing in a course in Parallel Computation is highly recommended for those pursuing a Master's Degree in Nuclear and Particle Physics. While some may argue that only computational physicists need this knowledge, the reality is that most physicists utilize computers extensively in their work. Parallel computation is a crucial skill that enhances problem-solving capabilities in various physics applications. However, the decision to take the course should consider individual coding proficiency; for those less inclined towards coding, it may not be beneficial. Conversely, for those with coding skills, focusing on programming GPUs or FPGAs could be more advantageous. Ultimately, the choice depends on one's specific career path and the opportunity costs associated with the time invested in learning parallel computation.
orochi
I am starting my Master's Degree in Nuclear and Particle Physics, should i invest in taking a course in Parallel Computation? I know the role that Parallel Computation has in particle physics, but is there any use in a particle physicst learning about parallel computation, or could it be considered a waste of time since only physicists specialized in computational physics need to know about parallel computation?
I would say yes, you should take the course. Virtually all practicing physicists use computers extensively, not just "physicists specialized in computational physics". Parallel computation is a very important tool to have in your toolbox.
Likes Delta2 and orochi
I don’t think it is that clear cut. If you are not a coder type, it is probably not a good idea. If you are a coder type, it might be better to learn to program gpu’s or fpga’s. Or parallel programming might be exactly what you need. It depends on your specific path. Everything has an opportunity cost.
TL;DR Summary: What topics to cover to safely say I know arithmetic ? I am learning arithmetic from Indian NCERT textbook. Currently I have finished addition ,substraction of 2 digit numbers and divisions, multiplication of 1 digit numbers. I am moving pretty slowly. Can someone tell me what topics to cover first to build a framework and then go on in detail. I want to learn fast. It has taken me a year now learning arithmetic. I want to speed up. Thanks for the help in advance. (I also...
guys i am currently studying in computer science engineering [1st yr]. i was intrested in physics when i was in high school. due to some circumstances i chose computer science engineering degree. so i want to incoporate computer science engineering with physics and i came across computational physics. i am intrested studying it but i dont know where to start. can you guys reccomend me some yt channels or some free courses or some other way to learn the computational physics.
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
