Least / Smallest / Minimum Detectable Difference
In summary, the minimum detectable difference, also known as the least or smallest detectable difference, is the smallest amount of change that can be detected between two measurements. It is an important concept in statistics, as it helps determine the accuracy and reliability of data. A smaller minimum detectable difference indicates a more sensitive measurement, while a larger one may lead to less precise results. It is commonly used in research studies and quality control processes to ensure that any differences observed are meaningful and not due to random chance.
Roger Dodger
42
In scientific experiment, we often have a physical property that can change but have no detectable impact on the measurement.
For example, suppose I have a mass of (say) 30 grams attached to a string passing over a pulley. I can add up to another 2 grams and the system doesn't budge.
In our lab manual, we call this additional 2 grams the least detectable difference and write the mass as 30 +- 2 grams. However, I cannot find any literature that uses this term. In fact, it doesn't appear to be discussed much at all.
What is the proper name for this effect? Is it the least detectable difference, minimum detectable difference, or smallest detectable difference. Or, is there a better term to use, such as (say) sensitivity uncertainty or sensitivity error?
Why, because of bearing friction? Your example would appear to be under-defined, so it's hard to know exactly what you are asking about. Certainly the FBD changes, right?
There is a predicted error in many measurements, and ways to describe that and to deal with it in data analysis. Can you give a different example, or refine your first one please? Thanks.
Yes, because of bearing friction a little mass can be added or subtracted without affecting the apparatus. Why? Because friction can take on any value (up to a maximum) to keep the system from accelerating.
It may be that other uncertainties, such as the standard deviation, already take this into account.
I don't think that's a valid example. You can measure the friction force by adding a 4g weight and measuring a(t) of the weight. That tells you the force (or torque) from friction. If you want to try to claim that your margin of error is +/-2g, you would have to make that only for masses that are less than the threshold to get the pulley moving.
I don't think this example helps us to try to answer your question. Can you come up with a different one? Are they all related to the level of noise in the measurement itself?
The force table, where you have three pulleys hanging by strings, with each string tied to a small loop centered over the table. Theoretically, there is one combination of masses and angles that should work. But you can change the angle slightly with no effect on the position of the loop. .
Not if you can make bearing friction arbitrarily small...
But I can't. I'm stuck with the pulleys we have in the cabinet.
I was thinking about this a bit more. Could this sensitivity error simply be a crude alternative to performing a large number of trials and finding the standard deviation? For example, suppose the nature of an experiment doesn't allow for a large number of trials, or even multiple trials. Could this least detectable difference serve as a crude estimate of the standard deviation? If so, perhaps this is why I haven't seen much mention of this error.
i'd suggest a couple of lines of reading...
  • Compare and contrast stiction with thermal noise and experimental error
  • Investigate dithering in noise reduction techniques in DSP hardware and algorithms...
I think that the definitive reference for reporting and handling error and uncertainty is given by the NIST publication below:
https://www.nist.gov/sites/default/files/documents/2017/05/09/tn1297s.pdf
Thanks. I'm not sure they address this issue, but I'll plow through it and see.
Likes Dale
I'm fully aware of the causes of stiction, but I'm not sure what you are asking me to do.
There is the concept of "just noticeable difference" as used in perception testing.
Likes Roger Dodger
Related to Least / Smallest / Minimum Detectable Difference
What is the concept of "least/smallest/minimum detectable difference"?
The concept of "least/smallest/minimum detectable difference" refers to the smallest difference or change that can be detected with a given level of confidence in a scientific study.
Why is it important to determine the "least/smallest/minimum detectable difference" in a study?
Determining the "least/smallest/minimum detectable difference" is important because it allows researchers to determine if the results of a study are statistically significant and meaningful. It also helps to ensure that any observed differences or changes are not due to chance.
How is the "least/smallest/minimum detectable difference" calculated?
The "least/smallest/minimum detectable difference" is typically calculated using statistical methods, such as power analysis or sample size calculation. These methods take into account factors such as sample size, variability of the data, and desired level of confidence to determine the minimum detectable difference.
Can the "least/smallest/minimum detectable difference" vary in different studies?
Yes, the "least/smallest/minimum detectable difference" can vary in different studies depending on the specific research question, study design, and statistical methods used. It is important for researchers to determine the minimum detectable difference specific to their study in order to accurately interpret the results.
How does the "least/smallest/minimum detectable difference" impact the reliability of a study?
The "least/smallest/minimum detectable difference" plays a critical role in the reliability of a study, as it helps to determine the accuracy and precision of the results. A smaller minimum detectable difference indicates a higher level of precision and reliability in the study's findings.
  • Atomic and Condensed Matter
  • Classical Physics
