Least Upper Bound Property ⇒ Archimedean Principle
In summary, the proof shows that if a totally ordered field ##\mathbb{F}## does not satisfy the Archimedean Principle, it also does not satisfy the Least Upper Bound Property. This is proven by showing that a set bounded from above in ##\mathbb{F}## does not have a least upper bound, leading to a contradiction. The definitions of l.u.b. and AP are also provided, as well as a note on using natural numbers in ##\mathbb{F}## as repeated field addition. The proof can also be generalized to any non-Archimedean linearly-ordered group.
Someone2841
44
Hello! I was wondering if this proof was correct? Thanks in advance!
Given: A totally ordered field, ##\mathbb{F}##.
Claim: Least Upper Bound Property (l.u.b.) ⇒ Archimedean Principle (AP)
Proof. I will show that the contrapositive is true; that is, if ##\mathbb{F}## does not have the AP, it does not satisfy l.u.b.
By assumption, ##\mathbb{F}## has some element S such that for each ##n \in \mathbb{N}, n < S## (that is, it does not satisfy AP). It follows from the totally ordered field axioms that ##kS^{-1} < k/n## for all ##n, k \in \mathbb{N}##. The set ##\{S^{-1},2S^{-1},3S^{-1},4S^{-1},\cdots\}## is then bounded from above (setting ##n=k## shows that ##kS^{-1}## is always less than ##1##) but does not have an upper bound in ##\mathbb{F}##.
Suppose that it does have a least upper bound ##l \in \mathbb{F}##, and so for any two upper bounds ##l, l’ \in \mathbb{F}, l≤l’##. Then ##l## must hold to the inequality ##kS^{-1} < l## for all ##k## (otherwise, ##l## wouldn’t be an upper bound for ##S##). But then ##2kS^{-1}< l ## implies that ##kS^{-1}< l/2 < l##, and ##l/2## is a smaller upper bound for ##S##, contrary to ##l## being the least upper bound. This means that our supposition that ##S## has an upper bound is false, and the l.u.b. does not hold for ##\mathbb{F}##. □
Definitions and Notes:
l.u.b. holds for ##\mathbb{F}## iff every non-empty set ##S \in \mathbb{F}## that is bounded from above has a least upper bound.
AP holds iff for any element ##s \in \mathbb{F}## there exists an ##n \in \mathbb{N}## such that ##s ≤ n.##
1 is the addition identify element for field addition, and multiplication by natural numbers is shorthand for repeated field addition. E.g., ##2S^{-1} = S^{-1} + S^{-1}##, and ##kS^{-1} = S^{-1} + S^{-1} + ... S^{-1}##, k times. If a natural number ##n## is used as an element of ##\mathbb{F}##, it is assumed to be repeated addition of the identity element n times.
This post got moved to abstract algebra (I was thinking of ##\mathbb{F}## as a generalization of the real numbers), and so I realize now that I could have just proven that any linearly-ordered group ##\mathbb{G}## that is not Archimedean does not have the least upper bound property. It can be done similarly but more concisely:
If ##G## is non-Archimedean linearly-ordered group, then there exists some ##g, h \in G## such that ##g^n < h## for all ##n \in \mathbb{N}##. This means that the set ##H=\{g^n : n \in \mathbb{N}\}## is both non-empty and bounded by ##h##.
Now suppose ##H## has a least upperbound ##l \in G##. As a upper bound, ##g^{n+1}<l## for all ##n## (since ##n## is arbitrary). But this means that ##g^n < g^{-1}l < l##, and ##g^{-1}l## is a lower least upper bound for ##H##, which is a contradiction. Therefore, if ##G## is a non-Archimedean linearly-ordered group, it does not satisfy the least upper bound property. □
Related to Least Upper Bound Property ⇒ Archimedean Principle
1. What is the Least Upper Bound Property?
The Least Upper Bound Property, also known as the supremum property, is a mathematical concept that states that every non-empty set of real numbers that is bounded above has a least upper bound, or supremum. This means that there is a smallest number that is greater than or equal to all the numbers in the set.
2. What is the significance of the Least Upper Bound Property?
The Least Upper Bound Property is significant in mathematics because it allows us to prove the existence of numbers without actually having to find them. It is a fundamental property of the real numbers and is essential in many areas of mathematics, including analysis and calculus.
3. What is the Archimedean Principle?
The Archimedean Principle, also known as the Archimedean property, is a mathematical concept that states that for any two positive real numbers, there exists a positive integer multiple of the smaller number that is greater than the larger number. In other words, no matter how small a positive number is, we can always find a larger number by multiplying it by a positive integer.
4. How are the Least Upper Bound Property and Archimedean Principle related?
The Least Upper Bound Property and the Archimedean Principle are closely related because they both deal with the order and completeness of the real numbers. The Archimedean Principle can be seen as a special case of the Least Upper Bound Property, where the set of numbers is the set of positive real numbers and the supremum is infinity.
5. What are some real-world applications of the Least Upper Bound Property and Archimedean Principle?
The Least Upper Bound Property and Archimedean Principle have many real-world applications, particularly in economics and finance. These principles are used to determine the maximum price that consumers are willing to pay for a product, as well as the maximum return on investment that investors are willing to accept. They are also used in optimization problems in engineering and computer science.
