Lebesgue Outer Measure .... Carothers, Proposition 16.1 ....
  • I
  • Thread starter Math Amateur
  • Tags
    Measure
In summary, Carothers is saying that if we replace ##J_k## by its closure, then the ##J_k## will be closed, not open, and the inequality between the two series still holds.
Math Amateur
MHB
3,998
48
TL;DR Summary
I need help with an aspect of the proof of Carothers' Proposition 16.1 ...
I am reading N. L. Carothers' book: "Real Analysis". ... ...
I am focused on Chapter 16: Lebesgue Measure ... ...
I need help with an aspect of the proof of Proposition 16.1 ...
Proposition 16.1 and its proof read as follows:
In the above text from Carothers we read the following:
" ... ... But now, by expanding each ##J_k## slightly and shrinking each ##I_n## slightly, we may suppose that the ##J_k## are open and the ##I_n## are closed. ... "Can someone please explain how Carothers is expecting the ##J_k## to be expanded and the ##I_n## to be shrunk ... and further, why the proof is still valid after the ##J_k## and ##I_n## have been altered in this way ... ...
Help will be appreciated ...
Peter
Replace ##J_k## by its closure and ##I_n## by its interior. These operations add/remove only begin or end points of the intervals so the lengths of the intervals are unaffected and the inequality with the two series keep valid.
Likes Math Amateur
Thanks for the help ...
I get the idea but shouldn't we replace ##J_k## by its interior and ##I_n## by its closure ...
Peter
You write:
" ... Interior makes the set smaller, the closure of the set makes the set larger. ... "
Yes ... but the problem I have is that we are told we may suppose that the ##J_k## are open and the ##I_n## are closed!
If we replace ##J_k## by its closure the ##J_k## will be closed not open ...
Peter
Math Amateur said:
You write:
Peter
You can quantify it if you like. As mentioned by @Math_QED we need only a point or two from not closed to closed, which doesn't change the length. And we need an arbitrary small, but positive distance to change from closed to open.
If there is a strict inequality, then it has a positive distance ##d>0## between the two. So the inequality still holds if we e.g. add ##d/2## to the smaller sum. Now we can write ##d/2=\sum_{n=1}^\infty d\left(\dfrac{1}{3}\right)^n##. This means we have ##(1/2)d/3^k## available to add on each side of every interval ##J_k## to make it open and still have a total length strictly smaller than ##d##.
Likes Math Amateur and member 587159
Thanks for your assistance fresh_42 ...
Your post was extremely helpful...
Peter
Related to Lebesgue Outer Measure .... Carothers, Proposition 16.1 ....
1. What is Lebesgue Outer Measure?
Lebesgue Outer Measure is a mathematical concept used in measure theory to assign a value to a set in a given space. It is defined as the infimum of the sum of the lengths of intervals that cover the set.
2. How is Lebesgue Outer Measure calculated?
Lebesgue Outer Measure is calculated by taking the infimum of the sum of the lengths of intervals that cover the set. This means that for a given set, we find the smallest possible sum of the lengths of intervals that cover the set.
3. What is Proposition 16.1 in Carothers' book?
Proposition 16.1 in Carothers' book is a proposition that states the relationship between Lebesgue Outer Measure and Lebesgue Measure. It states that for a set in a given space, if the Lebesgue Outer Measure and Lebesgue Measure are equal, then the set is considered to be Lebesgue measurable.
4. How is Proposition 16.1 used in measure theory?
Proposition 16.1 is used in measure theory to determine whether a set is Lebesgue measurable. If the Lebesgue Outer Measure and Lebesgue Measure are equal for a given set, then the set is considered to be Lebesgue measurable.
5. What is the significance of Lebesgue Outer Measure in mathematics?
Lebesgue Outer Measure is significant in mathematics as it provides a way to measure the size of sets in a given space. It is a fundamental concept in measure theory and has applications in various areas of mathematics, including analysis, probability, and geometry.
  • Topology and Analysis
