BWV
- 1,583
- 1,936
So Riemann integrals on ℚ can be <> 0 but Lebesgue integrals on ℚ all have measure zero?
Office_Shredder said:What is the definition of a Riemann integral on ##\mathbb{Q}##?
Integral is a number. It can not "have measure zero".BWV said:Lebesgue integrals on ℚ all have measure zero?
Riemann sums are usually defined as sums where an interval is partitioned into small intervals. You need to set up a definition. Also what is your definition of Lebesgue integral here?BWV said:so does the limit of Riemann sums not work inℚ? I was thinking it did, but not sure which is why I asked the question
Reading about the Lebesgue integral in the context of statistics and the examples of integration of ℚ = 0 like the common example of probability of picking a rational number from [0,1] in ℝ, but it seems an odd notion (i.e. I have something wrong) that integration only works in ℝ, or that Riemann works where Lebesgue does notmathman said:Riemann sums are usually defined as sums where an interval is partitioned into small intervals. You need to set up a definition. Also what is your definition of Lebesgue integral here?
What source are you reading about the Lebesgue integral with statistics/probability? I suspect that you may be overgeneralizing from the examples of Lebesgue integration you've studied.BWV said:Reading about the Lebesgue integral in the context of statistics and the examples of integration of ℚ = 0 like the common example of probability of picking a rational number from [0,1] in ℝ, but it seems an odd notion (i.e. I have something wrong) that integration only works in ℝ, or that Riemann works where Lebesgue does not
The Bill said:What source are you reading about the Lebesgue integral with statistics/probability? I suspect that you may be overgeneralizing from the examples of Lebesgue integration you've studied.
Say I looked at a few pages of a calculus book and saw that the three examples there were all definite integrals on the range [0,2]. Would it be correct for me to then assume that integrals are only ever done from 0 to 2?
You're missing the point that the Riemann integral is defined only on the Real numbers. There is simply no definition of a Riemann integral on the rationals.BWV said:its the first chapter of a Stochastic Calc for Finance book which is an intro to measure-theoretic probability. my takeaway was that Lebesgue measure -> Lebesgue integral, but confused as any Lebesgue measure on ℚ or ℤ is zero. The other option is Lebesgue integration requires a mapping from ℤ or ℚ to ℝ with measurable functions, like a step function for ℤ
integrating something trivial like ##y=2## on ℚ would not have any discontinuities in ℚ (whereas ##y=1/2 \sqrt x ## would be discontinuous in ℚ)The Lebesgue criterion for integrability states that a bounded function is Riemann integrable if and only if the set of all discontinuities has measure zero.[4] Every countable subset of the real numbers - such as the rational numbers - has measure zero, so the above discussion shows that Thomae's function is Riemann integrable on any interval. The function's integral is equal to 0 over any set because the function is equal to zero almost everywhere.
is Riemann integrable on any interval and the integral evaluates to {\displaystyle 0}
over any set.![]()
BWV said:Thanks, so calculus is only on the reals, but not sure technically why the Riemann integral could not work in ℚ for certain functions.
The limit of Riemann sums would not existStephen Tashi said:What do you mean by "not work"?
BWV said:The limit of Riemann sums would not exist
