LED current greater than source
In summary, if you are using the Arduino to drive high brightness LEDs, you should use a separate LED driver circuit. The Arduino cannot sink 100mA.
sema4ever
This is probably a simple matter. I have tried to find an answer on the web without success.
All published data on current-limiting resistor values is for LEDs with current rating less than power source. I am putting together an array for a museum of high brightness LEDs rated at VF 4.2, IFM 100 ma. The LEDs will be lighted one at a time by an Arduino micro-controller with output pins rated max 40 ma. The question: if I use the standard resistor value will that degrade either the LEDs or Arduino? (Will the LEDs suck too much current out of the Arduino pins?)
A one-second burst using either 10 or 100 ohms and the Arduino does light the LEDs. My concern is for the long term use in a museum setting.
You need to use a separate LED driver circuit -- the Arduino cannot sink 100mA.
Look at LED driver ICs, especially ones that use DC-DC converters for efficiency.
The non open-collector ports are usually current limited with ground or supply shorts and 40mA is optimistic directly from that type of port so if only one port supplies or sinks current each LED is safe with 10 ohm resistors. Open-collector ports could have a much higher drive capacity so it depends on how the circuit is constructed what current resistor should be used. I've used the 'high' drive outputs directly without resistors on micro-controllers to make displays but the little 10 ohm 1/4 watt resistors do make nice fuses if there is a wiring short from Vcc to ground at the LED. Staying within the chip total current limits (usually around 200mA for all ports) is what you need to keep in mind if you are lighting several LEDS directly from chip pins at the same time. If I were making something for long term display using a external driver chip like the ULN2308 would be better as then you could safely run each LED at full brightness.
A direct drive 100 ohm LED matix display running simple image transforms. It's not very bright driven directly from the uC.
https://flic.kr/p/e6xFR2
https://github.com/nsaspook/matrix_led
Likes berkeman
So when folks say "Arduino", they mean more than the uC, they mean a uC eval board? I guess that makes sense if the eval board has higher current IO drive buffers. It would still be better to use DC-DC based current sinks to keep the efficiency high. Thanks NSA!
The Arduino name was chosen by a group of people in Italy who designed boards with a CPU programmed to accept C language programs via a USB port..
They made the schematics of these boards and the software open source so that manufacturers in other countries are producing them as well, and quite legally.
As a result, they are available on EBay at very reasonable prices. The non genuine Arduino UNO R3 costs about $7 delivered.
When used commercially, or for educational purposes, buying the genuine Arduinos helps fund the development of these devices in Italy.
You can read about them here:
http://arduino.cc/en/Main/ArduinoBoardUno
Although the CPU is only 8 bit, the Arduino software operates at 32 bit, so that very large numbers can be handled.
They are quite capable of handling the large calculations used in controlling AD9850 Direct Digital Synthesis signal generators.
There is also a thriving market in add-on boards (called "shields") for these devices and these can be delivered for a dollar or so in some cases.
As you can see from here:
http://arduino.cc/en/uploads/Main/Arduino_Uno_Rev3-schematic.pdf
the bidirectional output pins are driven directly from the CPU (see lower right side of the schematic).
The specs for the Arduino do say that the output pins can deliver 40 mA each, but I couldn't find any assurance that all the pins could do this at the same time.
It would be safer to assume even the 40 mA per pin is optimistic and limit the output to 10 mA or so. This is plenty to drive a transistor base and allow safe switching.
if you need higher current just use a transistor with the gate attached to the uC. then use a sense resistor to measure the current.
Just to clarify that, you would not connect a transistor's base directly to the output of a microprocessor. That could destroy the transistor.
You would connect a suitable resistor between the microprocessor's ourput and the base of the transistor.
Typically, this resistor would be about 10 K and this would limit the maximum base current to about 0.5 mA.
The emitter of the transistor would be grounded and the collector would be connected to the LED in series with a current limiting resistor to a suitable power source.
A belated welcome to PF :)
That's correct and you probably wouldn't need a 10 k resistor, 1k should be enough. I have never used more when driving a transistor from a uPC or other logic output
look for an NPN transistor with a minimum Ic of 150mA to give a bit of headroom
cheers
Dave
Some transistors don't have bases.
Want to point out that you can vary the brightness of LED's by varying the switching waveform.
Also, since you are only lighting 1 LED at a time, you only need 1 resistor.
One other problem is that in many logic devices, logic "0" doesn't mean zero volts.
So, if an NPN transistor is used for the switching, even one volt of output is enough to turn it on via a small base resistor.
So if this might happen, a voltage divider or series diodes can be used to reduce the voltage and ensure that the switching device is turned off when it needs to be.
Or, as rightly suggested, enhancement mode FETs can be used for the switching.
Related to LED current greater than source
1. What does it mean when the LED current is greater than the source?
When the LED current is greater than the source, it means that the LED is drawing more electrical current than the source is able to provide. This can result in damage to the LED and potentially to the source as well.
2. Can an LED handle more current than the source is rated for?
No, an LED should not be exposed to more current than the source is rated for. Doing so can cause overheating and potentially lead to permanent damage to the LED.
3. What happens if an LED draws too much current?
If an LED draws too much current, it can cause the LED to overheat and potentially burn out. It can also lead to damage to the source and other components in the circuit.
4. How can I prevent an LED from drawing too much current?
To prevent an LED from drawing too much current, it is important to use a properly rated power source and to use resistors or other components to limit the current flowing to the LED. It is also important to properly calculate the current requirements of the LED and the circuit before powering it.
5. Are there any risks associated with using an LED with a higher current rating than the source?
Yes, there are risks associated with using an LED with a higher current rating than the source. This can lead to overheating, potential damage to the LED and the source, and can also pose a safety hazard. It is important to always use components within their specified ratings to ensure safe and reliable operation.
  • Electrical Engineering
