Lee Smolin tantalizing hint in TTWT
  • Thread starter RandallB
In summary, Marcus writes that Lee Smolin hints at a connection between the very large (GR scale) and the very small (QM scale). He tries to explain this by using the fundamental constants of physics, but is not clear about what he is saying. He suggests that Rm, the mass equivalent of the cosmo distance scale, is 10^-60 of Planck mass, which is too small. However, if we take a broad guesses at neutrino masses, the Rm would be getting progressively larger.
RandallB
1,550
Lee Smolin tantalizing hint in TTWP
Marcus
You seem to have one of the best reads on Lee Smolin and the points he makes.
I’m hoping you, or someone here, can help make sense of part of his book ‘The Trouble With Physics’.
On page 217 he refers to “another tantalizing hint”, relating the very large (GR scale) with the very small (QM scale).
He is dealing with Rd the distance scale and Rm the mass scale of the universe (my subscripts on R).
I understand arriving at 10^60 of Planck scale for Rd (page 204).
Lee then uses “just the fundamental constants of physics” to covert that to Rm.
Which constants did he apply; and what is Rm?
It would have been simple enough to just list them in his book!
His point is Rm give the same “order of magnitude” as the mass differences between the different types of neutrinos.
What is he talking about?
He could have listed this as well if it is such an important comparison.
I make the mass scale difference between electron and muon neutrinos as 10^5
and between muon and tau neutrinos as 10^2.
Maybe he means the full range for a 10^7 scale, I cannot tell from the book.
He seems about one paragraph short of making himself clear.
Can you, or does anyone, have a reference that might make sense of this.
Hi Randall,
I think I can help
No, it turns out I CANT help. I tried and got crazy numbers!
He must be using some way I don't know to get an energy (or mass) corresponding to a length.
HERE IS WHAT I TRIED which didnt work out:
If one is working in Planck units, the distance he is talking about (prob. square root of reciprocal cosm. const) is 10^60 Planck length.
So the mass, again in Planck units, would be (I'll explain later) 10^-60 Planck mass.
But Planck mass is just under 22 micrograms. So the mass he is talking about (the mass equivalent of the cosmo distance scale) is 10^-60 of that, or about 22 x 10^-66 grams...or 22 x 10^-69 kilogram.
THIS IS TOO CRAZY SMALL. So I am missing something. Maybe someone else can explain.
Here is what is going on in the approach I tried. If you look at fundamental constants like h, or h-bar, and c, you find that h-bar c is the product of any photon's (angular) wavelength times its energy
there is a locked in relation between vacuum wavelength and energy----they are reciprocals
so anytime you specify a length, you are simultaneously specifying an energy----and a big length corresp. to a small energy
there is often a little ambiguity because you don't know whether the author is talking h or h-bar.
In my experience they most often mean h-bar-----they think of it as somehow more fundamental
(and they secretly prefer to think of the "angular wavelength" of something which is the length of a full cycle divided by 2 pi)----
but that 2 pi ambiguity only involves some order-one indefiniteness so it does not have much affect on these order-of-magnitude discussions.
think of the energy of a photon which has that huge wavelength----it has to be miniscule
this is giving funny answers, I have to check.
LATER: I went and looked at that passage on page 217 that you were asking about. And I can't interpret it.
I will give it another try later, if nobody else shows up and straightens us out.
Well you point me in a better direction for Rm
I had been thinking of a larger number like the total mass, your smaller number makes much better sense.
By taking a broad guesses at neutrino masses, since they are not measured very precisely yet anyway, I think I can define a reasonable Kilo-gram Mass Scale for each neutrino as follows:
Code:
[u]Neutrino          eV            Kg-mass     Kg-mass scale[/u]
 electron        1 eV         2x10^-36             ^-36
  muon          100 KeV       2x10^-31             ^-31
   tau           10 MeV       2x10^-29             ^-29
Now relating those scales I still cannot do,
as you say the numbers seem to be crazy small for Rm.
But since this is related to measurements from WMAP
If we look at the Dipole, Quadra pole and Octa-pole;
Wouldn’t the Rl be getting progressively shorter for each.
Thus the Rm would be progressively larger.
Maybe something here is where he sees a correlation,
if not in direct scale values, maybe it the ratios of the two sets of three?
Related to Lee Smolin tantalizing hint in TTWT
What is Lee Smolin's tantalizing hint in "The Trouble with Physics"?
Lee Smolin, a theoretical physicist and author, proposed in his book "The Trouble with Physics" that the theory of quantum gravity may require a radical rethinking of our current understanding of space and time.
What evidence does Smolin present for his theory?
Smolin suggests that the lack of progress in reconciling the theories of general relativity and quantum mechanics could be a sign that we need to shift our focus to a new approach to understanding gravity.
How does Smolin's theory differ from other theories of quantum gravity?
Smolin's theory, called "loop quantum gravity", suggests that space is not continuous but rather made up of discrete units, much like how matter is composed of atoms. This is in contrast to other theories that propose a continuous and smooth space-time.
What implications does Smolin's theory have for the future of physics?
If Smolin's theory is correct, it could mean a major shift in our understanding of the fundamental laws of the universe. It could also open up new avenues for research and potentially lead to a unified theory of quantum gravity.
What criticisms have been raised against Smolin's theory?
Some critics argue that there is not enough evidence to support Smolin's theory and that it is too early to abandon the current approaches to quantum gravity. Others have raised concerns about the feasibility and testability of the theory.
  • Beyond the Standard Models
  • General Discussion
