MHB Leeward 206 {8.13} Integral at infinity
  • Thread starter Thread starter karush
    Infinity Integral
The discussion focuses on evaluating the improper integral I = ∫₀^∞ e^{-ax} dx for a > 0. The substitution u = -ax is introduced, leading to a transformation of the integral limits. Participants emphasize the necessity of introducing a finite terminal, t, to properly handle the improper integral and evaluate its limit as t approaches infinity. The final result of the integral is confirmed to be I = 1/a. The conversation highlights the importance of understanding the limits and techniques for evaluating improper integrals.
karush
MHB
$\tiny\text{Leeward 206 {8.13} Integral at infinity}$
$$I=\int_{0} ^{\infty} e^{-ax} \,dx \ a>0 =
\begin{align}\displaystyle
u& = -ax &
du&=-a \ d{x}
\end{align} \\
\text{then} \\
I=-\frac{1}{a}\int_{0} ^{\infty} e^{x} \,dx
=-\dfrac{\mathrm{e}^{-ax}}{a}+C \\
\text{hopefully, wasn't sure about the + C}$$
$\tiny\text{ Surf the Nations math study group}$
When you make the substitution you need to change your limits in accordance with the substitution. Let's begin with:
$$I=\lim_{t\to\infty}\left(\int_0^t e^{-ax}\,dx\right)$$ where $0<a$
Now, if we use the substitution:
$$u=-ax\,\therefore\,du=-a\,dx\implies dx=-\frac{1}{a}\,du$$
and use the rule:
$$\int_a^b f(x)\,dx=-\int_b^a f(x)\,dx$$
We obtain:
$$I=\frac{1}{a}\lim_{t\to\infty}\left(\int_{-t}^0 e^{u}\,du\right)=\frac{1}{a}\lim_{t\to\infty}\left(\left[e^u\right]_{-t}^0\right)=\frac{1}{a}\lim_{t\to\infty}\left(1-e^{-t}\right)=\frac{1}{a}$$
$\text{Why did you introduce t ?}$
That's how I was taught to handle improper integrals. :)
The reason Mark was taught that is how you handle improper integrals is because a definite integral requires FINITE values for the terminals of the integral. So by applying a finite terminal (in this case, "t") you can then evaluate the improper integral by seeing what happens as that finite value is increased without bound, in other words, what is the limiting value as $\displaystyle \begin{align*} t \to \infty \end{align*}$...
