Legendre Expansion solution to sphere of potential V with charge q outside
In summary, the conversation is discussing the solution to Laplace's equation in spherical coordinates with azimuthal symmetry. The problem of a sphere held at potential V with a charge 1 outside a distance d is being discussed and a possible solution using image charges is suggested. The use of Legendre polynomials is also mentioned, but it is not clear how to apply them in this specific case. The conversation ends with a request for a solution utilizing Legendre polynomials.
phys_student1
106
Hi,
It seems that there is no much examples of this particular case.
OK, we all know how to write the general solution to Laplace equation in spherical coordinates in terms of Legendre polynomials (when there is azimuthal symmetry).
There are a lot of cases here but I would like to know how to attack the problem of a sphere held at potential V with a charge 1 outside a distance d.
I know you will have an image charge inside the sphere a distance d*a^2 from sphere's center.
But how to account for this system of image charge and original charge? Can we simply add a term (outside the sum of Legendre Polynomial) ?
Thanks in advance
You can put an image charge, q"=V/a+qa/d, at the center of the sphere of radius a.
You don't need Legendre polynomials for this.
The original image charge should be at d'=a^2/d.
I understand the image charge method.
What I seek is the solution utilizing Legendre Polynomials.
Again, I understand Legendre Polynomial solution as applied to different cases, but not this one.
Related to Legendre Expansion solution to sphere of potential V with charge q outside
1. What is Legendre Expansion solution to sphere of potential V with charge q outside?
The Legendre Expansion solution to sphere of potential V with charge q outside is a mathematical method used to determine the potential at any point outside a charged sphere. This method uses Legendre polynomials to expand the potential function, allowing for a more accurate and efficient calculation.
2. How does the Legendre Expansion solution work?
The Legendre Expansion solution works by expanding the potential function in terms of Legendre polynomials, which are mathematical functions that can represent a wide range of shapes and patterns. By using these polynomials, the potential function can be expressed in a series of terms, making it easier to calculate.
3. What is the significance of using Legendre polynomials in this solution?
Legendre polynomials are particularly useful in this solution because they are orthogonal, meaning they are independent and do not overlap. This makes them ideal for representing a spherical shape and allows for a more accurate calculation of the potential function.
4. Are there any limitations to using the Legendre Expansion solution?
While the Legendre Expansion solution is a powerful and widely used method for calculating potential in a charged sphere, it does have limitations. This solution assumes that the charge is evenly distributed on the surface of the sphere and does not take into account any irregularities or variations in the charge distribution.
5. Can the Legendre Expansion solution be applied to other shapes besides a sphere?
Yes, the Legendre Expansion solution can be applied to other shapes besides a sphere. However, the equations and calculations may become more complex, as different shapes may require different types of polynomials. Additionally, the accuracy of the solution may vary depending on the shape being analyzed.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
