Lemon battery without copper and zinc metals
In summary, a video online shows a way to light an LED using a single lemon without copper and zinc nails. However, this method is likely a fake and may involve concealed wires or a hidden battery inside the fruit. It is possible that a single cell made with magnesium and copper plated legs could give enough voltage to light an LED, but it is not a reliable or efficient method.
fog37
1,568
108
Hello,
I have seen a video online that shows how a LED can be lit using a single lemon without using a copper and a zinc nail. They simply stick the LED into the lemon.
What does that work? I know the lemon contains the electrolyte but don't we always need to dissimilar metals for the battery to work?
thanks!
I think you need a lime for it to work.:rolleyes:
yeah, true. But why?
It was a joke, the video is a poor fake.
If you wanted to fake it, could you plate one leg with zinc? It would look silver on a video and maybe pass for an "untreated" LED. The anodic index of silver solder is the same as copper according to the table here:
http://www.engineersedge.com/galvanic_capatability.htm
Let say you had a single cell made with a magnesium/copper plated tiny surface reaction area legs LED that might give 1.6 volts (the penny/nail open voltage is about 0.9) open circuit and drop to half that voltage value with a few micro-amp load because of high internal resistance. Would that work to light an LED?
Likes Bandit127
Possibly there could be concealed wires or a battery buried inside the fruit?
Likes rbelli1
It is definitely a shoop. I can tell from the pixels. Third one from the left has shifty eyes.
BoB
Related to Lemon battery without copper and zinc metals
1. How does a lemon battery work?
A lemon battery works by harnessing the chemical reaction between the citric acid in the lemon and the metal electrodes to create an electrical current. This current is produced when the electrodes, typically copper and zinc, react with the acidic lemon juice to form a circuit.
2. Can a lemon battery work without copper and zinc metals?
Yes, a lemon battery can still work without copper and zinc metals. Other types of metals such as aluminum, iron, or even coins can be used as electrodes to create a similar chemical reaction and produce electricity.
3. How long will a lemon battery last?
The lifespan of a lemon battery depends on the freshness and acidity of the lemon, as well as the type of metals used as electrodes. On average, a lemon battery can generate electricity for up to 8-10 hours before the lemon juice runs out.
4. What can a lemon battery power?
A lemon battery can power small electronic devices such as LED lights, calculators, or even a small motor. However, the amount of power generated is relatively low compared to traditional batteries, so it may not be suitable for larger devices or appliances.
5. Are there any safety concerns with making a lemon battery?
As with any science experiment, it is important to take safety precautions when making a lemon battery. Avoid touching the metal electrodes while they are connected to the lemon, and be careful not to ingest any lemon juice. It is also important to properly dispose of the materials and clean up any spills afterwards.
  • Electrical Engineering
  • Materials and Chemical Engineering
16K
