Length contraction and the speed of light
In summary: that the contraction is a direct consequence of the first and second postulates of special relativity."
  • #36
Stephanus said:
In 'Janus' train, the lights come from the train to the platform.
https://www.physicsforums.com/threads/length-contraction.817911/#post-5135255
Do in your pictures the lights come from the platform?
The light rays come from the middle of the train towards each end of the train. They are thin yellow lines inclined at 45o.
  • #37
Thanks!
  • #38
harrylin said:
Please explain the null result of a moving interferometer, assuming that SR's postulates are correct. :cool:
PS. note that no simultaneity convention is used in such measurements, which very much simplifies the analysis.
If we measure length of something that is moving, there is always simultaneity convention. Length contraction is cause of this simultaneity convention, there is no "real" contraction.
One can measure length of moving object only using one statonary clock and measure endpoints as they flyby. But even then measurement is less because his clock is running slower (yes, slower and the reason is simultaneity convention)
  • #39
Mentz114 said:
You do need clocks. "I time the flash to fire such its light will reach the film when the center of the ruler is above the center of the film." What procedure is used to determine the correct time to fire the bulb ?
You could just keep repeating the experiment with randomly varied firings until you get an image reasonably centered on the film (make it a CCD for reusability). That was the point of my comment: "if you get the picture". As long as you get a picture, you have your measurement. So, imagine a 'ruler gun' that keeps identical shooting rulers, and a flash bulb that fires randomly. Continue till you get a picture.
Likes 1977ub
  • #40
Your clock never runs slow. You conclude clocks moving relative to you run slow. The one clock measurement you describe depends on simultaneity only in that you have to know the speed of the rod. To measure speed you either need two synchronized clocks or rely on SR Doppler formula which is based in Einstein clock synch.
In my proposed experiment, the simultaneity requirement is hidden in the geometry of the experiment. The set up that the line from film center to flash bulb is orthogonal to the motion of the ruler builds in simultaneity of the bulb/film frame. To me, though, it is hard not to accept this as comparably 'physically real' as an measurement we make about a moving body.
  • #41
PAllen said:
Suppose I have 1 meter square sheet of film, and flash bulb placed e.g. 100 meters above it. A 2 meter (rest length) ruler, moving parallel to the film plane in the direction of its length, and e.g. 1 cm above this plane, is approaching. I time the flash to fire such its light will reach the film when the center of the ruler is above the center of the film. The ruler is moving at .968 c. What I get is an image on the film of a ruler shadow 1/2 meter long. What is your (Mentz114) philosophy for treating this as 'not physical'? No coordinates or conventions are involved. Just a few objects at mutual rest, and another object moving relative to those.
For this to be a valid length you do have to adopt the convention that the one way speed of light is isotropic. That convention is equivalent to Einstein's synchronization convention in that frame.
  • #42
There is a more basic way simultaneity is built in - the geometry of the line from film center to bulb being orthogonal to ruler motion. In a different (e.g. ruler) frame, they won't be orthogonal, and the image would be considered affected by motion (of film) during the arrival time difference at one end of the image versus the other.
I'm only posing this as an example of something that feels like it should be considered 'a real length measurement'. It is as much a measurement of length of a moving object as transverse doppler is of time dilation (if you don't assume isotropy of light speed, you get different Doppler formula).
  • #43
And of course, travelers on the ruler will decide that photons from the bulb flash hit different parts of the ruler at different times, and different parts of the image on the film are created at different times.
Likes CycoFin
  • #44
My clock is running slow if I check the clock on one end of the rod, wait, and then check the time on the other end of the rod as they pass by and calculate difference and compare that to my stationary clock. These two rod clocks are running slow if I measure them with two different spots, but time elapse they show on my one spot is running faster than mine. This is because rod have different concept of simultaneously.
  • #45
CycoFin said:
If we measure length of something that is moving, there is always simultaneity convention. [..]
MMX is totally indifferent about simultaneity conventions. However, it is dependent on the light postulate, and the simultaneity convention is also based on that postulate. Imagine observations using the solar frame, as you may do according to the relativity postulate. On Earth is a slowly rotating MMX interferometer near the Earth's equator, so that it circles the Sun in one year. Assuming that the light postulate is correct, how do you explain the null result without length contraction?
PS in fact you can pick any inertial frame you like for the physical analysis, as long as you stick to that one (it's faulty, or at least messy, to change calibration of measurement equipment during a measurement).
  • #46
There is length contraction but IMO it has very bad name. Length illusion would be better name for the fact that we measure moving objects shorter.
Actual physical length is not contracted. We measure shorter lengths because we "see" objects future/past points depending what point of the object we choose to be our reference point.
Back to train example. Let moving train be 100m measured by people on train. Let moving train measured by station people to be 50m. During this measurement point 0m station observer looks train's clock on that end. Same time (defined by station people) 50m point station observer looks train's clock on that point and if these two compare results they find out that train's clocks have different readings (so that 50m clock have more time, we can "see" the future of the train).
Let there be station observer on 200m mark. His recorded time from the clock of the end of the train as the end was bypassing him equals to 0m point observer for the start of the train. This is same time for train observers so train people measures that 200m station equals to their 100m train.
  • #47
Mentz114 said:
You are missing the point. I have an extended object that lies along its local x-axis. Its length is the integral I gave.
Not sure who is missing the point. You probably mean its proper length. Proper length is the length of an object as measured with respect to a reference system that is in the same state of motion and which is pretended to be in rest. It's similar to such things as magnetic fields and kinetic energy. The proper kinetic energy and magnetic field of an electron in uniform motion are zero. Are kinetic energy and magnetic field therefore "non-physical"? Or are the kinetic energy and magnetic field of that electron "non-physical", but the kinetic energy of a power drill and the magnetic field of an electromagnetic coil "physical"?
Then I have an apparatus which is moving inertially along the same axis wrt the object. What happens when the apparatus tries to measure the length of the moving object ? There is no symmetry or ambuguity. Or frame dependence.
There is no ambiguity, but there is full symmetry between inertial frames. However, your example is unnecessarily complicated because of relativity of simultaneity; it's a bit of a red herring. Please correct me if I'm wrong, but I get the impression that you think that length contraction is caused by RoS. I just gave the example of MMX which in the general case as originally considered is indifferent about RoS, and in a parallel thread I demonstrated the need of length contraction if the two postulates are true (in combination with time dilation), before looking at simultaneity conventions. - #48
You can choose any simultaneity convention you like, it changes nothing for the physics.
[..] will ##L/\gamma## be proven to be an unmeasurable quantity ?
Once more, I still wonder if you think:
- is ##t/\gamma## an unmeasurable quantity ?
- is Ekin an unmeasurable quantity ?
  • #48
Forgive me if this is off point or just semantics, but isn't any measurement we make of any system 'real' in that it tells us something about the system we are measuring? But it is how we interpret the measurement that is important. I would of thought that in the example of the ruler given, the 'photo' taken is measuring the effects of relativistic speeds on the observations of length of an object, as seen from a different frame. It is not measuring the physical or 'real' properties of the object or in this case the ruler. As that isn't possible for all properties unless one is at rest wrt to the ruler and you can physically examine it. So in that respect it isn't a 'real' measurement of the length of the ruler.
Anyway, what I was really interested in is how the ruler would look if we could take a high resolution photo of it at that speed. The meter ruler would appear shorter of course but would the mm increments all be equidistant or would they appear closer together at the ends or in the middle etc. The reason for my asking is I was curious how natural light (so coming from all directions) would reflect off the surface of the ruler and into the camera lens with the ruler traveling at such high speeds.
  • #49
Check this https://en.wikipedia.org/wiki/Terrell_rotation
  • #50
CycoFin said:
[..] Length illusion would be better name for the fact that we measure moving objects shorter. [..] Same time (defined by station people) 50m point station observer looks train's clock on that point and if these two compare results they find out that train's clocks have different readings (so that 50m clock have more time, we can "see" the future of the train). [..]
In this thread other examples were given in which no clocks are used, but just two postulates from which such "illusions" follow. Of course, you are free to call the postulates of SR illusions, as they refer to physical measurements and not to physical reality, which may be somewhat hidden to us. We cannot do better than that.
  • #51
rede96 said:
Forgive me if this is off point or just semantics, but isn't any measurement we make of any system 'real' in that it tells us something about the system we are measuring? But it is how we interpret the measurement that is important. I would of thought that in the example of the ruler given, the 'photo' taken is measuring the effects of relativistic speeds on the observations of length of an object, as seen from a different frame. It is not measuring the physical or 'real' properties of the object or in this case the ruler. As that isn't possible for all properties unless one is at rest wrt to the ruler and you can physically examine it. So in that respect it isn't a 'real' measurement of the length of the ruler. [...]
I'm afraid that the kinetic energy and magnetic field of electrons in an electron beam are always "unreal" or zero when examined with co-moving measurement equipment ...
According to SR, the effect of very high speed on an object is that it will be length contracted according to measurements with the "rest" system, while the proper length will be the same as the length in rest. All verified experiments up to this day are consistent with that prediction.
  • #52
It seems that all of the physics content has finished and now we are just discussing semantics and philosophy. Thread closed.
  • #53
There is nothing controversial in this post - I just want to finish off what I started in the the earlier thread which descended into argument.
I made the calculation based on the definition of rest length ##L=\int_0^L dx## which means we are adding up the notches on a ruler laid alongside the object we are measuring. Because there is no time in that definition, any time gaps between measuring the ends do not affect the result ( the object is not moving wrt the ruler).
When we define a similar quantity but from the frame of a moving ruler, we get ##L'=\int_0^{L/\gamma} dx'##. The change in the upper limit is because the projected length of ##L## onto the ##x'##-axis is ##L/\gamma## ( this can be shown).
From the LT joining the rod frame ( unprimed) and the moving ruler frame (primed) we have ##dt'=\gamma(dx+\beta dt)##. So the integral ##L'=\int_0^{L/\gamma} dx'## now has a time part, and to complete it we need two times ##t_0,t_1## for the limits of the integration. It seems obvious that these correspond to the times of the measurements of the ends of the rod.
Suppose we want the result of the measurement to be ##L##. This means that the integrand should integrate to ##\gamma L##, to cancel the ##\gamma## in the upper limit. The only solution of ##{dx'}=\gamma\beta dt + \gamma dx = \gamma dx## is ##dt=0##. To find the operational delay ( the delay in the ruler frame) we put ##dt=0## into ##dt'=\gamma dt + \gamma\beta dx## to get ##dt'=\gamma\beta L##. In the rod frame the measurements appear simultaneous (##dt=0##).
I think this agrees with other similar calculations.
Now I repeat the with requirement ##L'=L/\gamma##. This means the integrand in ##L'## must evalute to 1 (unity).
The rest is algebra and gives
##dt'=(1-\frac{L}{\gamma})/{\beta}##
This is fine if ##\beta^2>0## and is positive for ##L<c\gamma## (putting ##c## back into ##L##) which includes most laboratories. If it goes negative it means we waited too long and the rod is gone.
So according to this ##L/\gamma## can be the result of a suitable timed measurement.
There's nothing here that isn't known but I haven't seen it shown convincingly in a coordinate independent way.
What the experimenter chooses here is a time delay. I'm not sure how that relates to clock-synchronisation. Defining everything as integrals along curves removes the need for synchronisation, I think.
(I'd like to thank @harrylin, @A.T., @PAllen, WannaBeNewton and others who responded usefully in the previous thread)
  • #54
Sort of. Instead of picking different clock synchronizations for the different frames, you're picking different spacelike curves along which to integrate. (Drawing a spacetime diagram makes this obvious.)
You could say that the rulers in relative motion pick out the different spacelike curves for you, but that's not really true, because the rulers are not spacelike curves; they are world tubes, and the spacelike curves in question are particular curves picked out of those world tubes. What picks them out? A definition of simultaneity--which events in the different rulers' world tubes are considered as being "at the same time", so that the spacelike curve they form realizes a "proper length".
It's true that, for the special case of a ruler in free fall in flat spacetime, the spacelike curves that define its "proper length" at each instant of time can be picked out by an independent criterion, namely, being orthogonal to the worldlines of all the points of the ruler. But as soon as you introduce either non-inertial (or more precisely, non-uniform) motion, or spacetime curvature, that uniqueness goes away.
None of this invalidates what you're saying; I just think it's important to make clear the limitations of any definition of "length".
  • #55
Please do not try to reopen this topic.
