- #36
Hans de Vries
- 28
maartenrvd said:@Hans:
From your paper "The simplest, and the full derivation of Magnetism as a Relativistic side effect of electroStatics" after equation 8: "We see that the field of the moving electrons is the same as the field for the electrons at rest. The result is independent of the speed of the electrons."
Don't get me wrong, I'm just trying to understand, but how does this match with the fact that a magnetic force can be transformed into an electric force in the correct reference frame, i.e. the frame of the observer?
The electron density is only equal to the ion density in one
single reference frame. If the test charge is at rest in this
reference frame then it feels no force. The speed of the
electrons and ions is not important, They can move both
in this reference frame but the only criteria is that the charge
densities are equal.
The proof that the field of the wire is only dependent on the
densities and not the speed, even though the individual charge
fields are velocity dependent, is given in section 2 here.
http://physics-quest.org/Magnetism_from_ElectroStatics_and_SR.pdf
The reason that the densities of the electrons and ions are
different in all other reference frames is non-simultaneity.
For instance: more electrons have entered the wire if Δt
is positive there, and consequently less electrons have left
the wire at the other end because Δt is negative at that
end of the wire.
maartenrvd said:Than what is the correct reference frame for a charge particle to feel no force? Is it when it is stationary with the electrons or is it when it is stationary with the protons?
See DaleSpam's post.
Regards, Hans
