Length Contraction in Accelerated Frame
In summary: Yes, I would agree with that. But that has nothing to do with SR. It's just a result of the material of the apple not being able to withstand the extreme forces involved.I jst would say SR fails to explain all the nuanced interactions that would happen to a body as a result of acceleration.SR is not a theory of materials and their responses to stress. It is a theory of spacetime and how objects move through it. It is not meant to explain all the details of a complex system like an exploding apple. In summary, special relativity can handle acceleration and does not predict any deformation in the y and z axis' if an object is accelerating in the x axis. While
sqljunkey
181
I was wondering, would there be a length contraction (or expansion) in the z and y axis' if an object was accelerating in x axis? I know that in special relativity there is no deformation in the y and z axis' if the object is moving in the x axis.
I was looking a this paper for clarification.
Special relativity can handle acceleration just fine (what it can't handle is curved spacetime). So if by "length contraction" you just mean the measured dimensions of the object along the z and y-axis in a fixed inertial frame, the answer is no regardless of whether the object is accelerating along the x-axis or not.
This paper does not appear to be peer-reviewed, and is discussing a fairly advanced subject. So it's probably not a good source for someone without a fairly advanced background in relativity.
Also, it's not clear that the paper is talking about the simple question you pose, which I answered above. It appears to be talking about more complicated questions. (I haven't read it all yet, only skimmed, but that's my initial impression.)
If an object is accelerating in special relativity isn't it creating a curved coordinate system against with time and position? If I was switching between my flat spacetime to the accelerating spacetime wouldn't I have to undergo some curved coordinate transformations?
I don't understand how special relativity can handle acceleration, if I had an elevator with someone in it, and it was accelerating this person would feel a force, which means there is curved spacetime activity going on.
Coordinate systems are not physical things. They're abstract human conventions. You can describe the motion of an accelerating object perfectly well in standard inertial coordinates.
There is no such thing as an "accelerating spacetime". An accelerating object doesn't change the spacetime geometry it's moving in.
Then you need to spend some time learning SR.
Curved spacetime is not the same as acceleration or feeling a force.
what about equating an accelerating elevator with an elevator sitting on Earth ? Where the person sitting inside the elevator wouldn't feel a difference.
That's an example of the equivalence principle. But the equivalence is only local; what it's telling you is that the spacetime around the Earth is locally flat, just like the spacetime of the accelerating elevator. The difference in the Earth case is that the spacetime is not globally flat, only locally flat. In the case of the accelerating elevator, the spacetime is globally flat (at least, it is for the scenario we are discussing in this thread). But you can't tell the difference from inside the elevator, i.e., from local measurements. You can only tell by making measurements over a wide enough region of the spacetime to determine whether it is curved or flat globally.
I still don't understand how special relativity would describe length contraction. Suppose I put an apple down in a rocket and accelerate with so much force that I explode the apple into a million pieces, how is special relativity going to explain that transformation? If this was all special relativity I could plot the trajectory of the atoms and molecules of this apple I guess.
Using the Lorentz transformation.
It doesn't by itself; you need a theory of the material of the apple and how it responds to stress. But that transformation is not length contraction and has nothing to do with length contraction, so you should not expect SR to explain it.
What do you mean by "all special relativity"? Again, if you're expecting SR, all by itself, to give you a complete theory of materials and how they respond to stress, you're expecting too much.
Yes, you could do that. But SR by itself won't tell you what those trajectories are. Again, you would need a theory of the material of the apple and how it responds to stress. Any such theory must be consistent with relativity, but that doesn't mean relativity by itself tells you what it is.
well that is why I was asking, is there going to be some kind of deformation in the apple's y and z axis' if the rocket with the apple inside were to accelerate violently in the x direction. and I think you would agree that if the apple exploded into 1 million pieces y and z would be covered in apple.
and I think even with an infinite rigid body there would be distortions in both axis's.
And the answer to that question is no, as I've already said.
And this is a different question, which, as I've already said, has nothing to do with special relativity. It has to do with the physics of materials and stresses. Trying to view it as a relativity problem is only going to confuse you.
There is no such thing in relativity; relativity places finite limits on the rigidity of materials.
Not if the body is intact and only moving along the x axis. If the body is not intact, if it explodes or otherwise comes apart, then, once more, its behavior is not a matter of relativity; it's a matter of the physics of materials and stresses.
As a result of acceleration just by itself, it does. As a result of acceleration that results in explosions or other such things, no, of course it doesn't. See above.
The OP question has been answered and the thread is degenerating into topics irrelevant to the OP. Thread closed.
Related to Length Contraction in Accelerated Frame
1. What is length contraction in an accelerated frame?
Length contraction in an accelerated frame is a phenomenon in which an object's length appears to decrease when observed from a frame of reference that is undergoing acceleration. This is a result of the theory of special relativity, which states that the laws of physics are the same in all inertial frames of reference.
2. How does length contraction differ from time dilation?
Length contraction and time dilation are two consequences of the theory of special relativity. While length contraction refers to the apparent decrease in an object's length in an accelerated frame, time dilation refers to the slowing down of time in a frame that is moving at a high velocity. Both of these phenomena are a result of the relativity of simultaneity.
3. Does length contraction only occur in accelerated frames?
No, length contraction can also occur in frames of reference that are moving at a constant velocity. However, it is more pronounced in accelerated frames due to the additional effects of acceleration on space and time.
4. How is length contraction measured?
Length contraction is measured by comparing the length of an object in its rest frame to its length in a moving frame. This can be done using various techniques, such as using a ruler or a laser interferometer. The amount of length contraction can also be calculated using the Lorentz transformation equations.
5. Does length contraction have any practical applications?
Yes, length contraction has been observed and measured in various experiments, and its effects are taken into account in many practical applications. For example, it is crucial in understanding the behavior of particles in particle accelerators and in the design of spacecraft and satellites. It also plays a role in the accuracy of GPS systems and in the synchronization of clocks in high-speed communication systems.
