Length Contraction Problem for a Rod in a Spaceship
The discussion centers on the length contraction of a rod moving in a spaceship, with participants debating whether the rod is at rest relative to the spaceship. One participant argues that the problem statement indicates the rod is moving at 0.4c relative to Earth, suggesting it cannot be assumed to be at rest in the spaceship. Another points out that while the observer is at rest relative to the spaceship, the spaceship's velocity relative to the rod is unspecified. This ambiguity leads to different interpretations of the scenario, particularly regarding the implications of the rod's motion. The conversation highlights the complexities of relativistic physics and the importance of clearly defined reference frames.
Skyxplorer
A rod has length of 1m. It is moving in a spaceship with velocity 0.4c relative to the earth. The length of the rod measured by an observer in the spaceship will be
(A) 1m
(B) 0.9m
(C) 0.5m
(D) 0.25m
Shoudnt answer be A since for observer in spaceship rod is at rest.
Yes
Thank you for confirming
One might take is as a good assumption, but nowhere do I see it mentioned that the rod is at rest relative to the spaceship.
(In fact, it kind of says "it (the rod) is moving in a spceship" so I wouldn't be too quick with that assumption.)
In fact it clear from the statement that it (the rod) is moving
Skyxplorer said:
##\dots## with velocity 0.4c relative to the earth.
It is safe to assume that the observer is at rest relative to the spaceship, but we are not told the velocity of the spaceship (and observer) relative to the rod.
Answer (B) is consistent with the spaceship being parked on the Earth and the rod passing through two diametrically opposing openings at 0.4c but that's stretching it. :oldsmile:
