maverick280857
- 1,789
- 5
Hi, this isn't exactly homework, as I'm teaching myself, but I thought this forum would be more appropriate for it.
(Page 36, Introduction to Special Relativity by Wolfgang Rindler)
An 18-foot pole, while remaining parallel to the x-axis, moves with velocity [itex](v,-w,0)[/itex] relative to frame S, with [itex]\gamma(v) = 3[/itex], and u, w positive. The centre of the pole passes the centre of a 9-foot hole in a plate that coincides with the plane y = 0. Explain, from the point of view of the usual second frame S' moving with velocity v relative to S, how the pole gets through the (now 3-foot) hole.
[tex]\vec{u} = (v, -w, 0)[/tex]
[tex]\vec{u'} = (u_{1}', u_{2}', u_{3}')[/tex]
Velocity transformation equations:
[tex]u_{1}' = \frac{u_1 - v}{1-\frac{u_1 v}{c^2}} = 0[/tex]
[tex]u_{2}' = \frac{u_2}{\gamma(1-\frac{u_1 v}{c^2})} = -\gamma w[/tex]
[tex]u_{3}' = \frac{u_3}{\gamma(1-\frac{u_1 v}{c^2})} = 0[/tex]
So, [tex]\vec{u'} = (0, -\gamma w, 0)[/tex]
The proper length of the rod is 18ft. Relative to an observer in S', the rod has a length of 9 ft and is moving along the y'-axis with a velocity of [itex]-3w \hat{y}[/itex] ft/s. Also, relative to this observer, the hole is now a 3 ft hole moving along the negative x'-axis with a velocity [itex]-v \hat{x}[/itex].
In the S' frame then, the 9 ft rod is moving down along the y' axis, trying to enter a hole that is moving along the x'-axis in the negative x' direction. This is as far as I've gotten.
How does one explain this observation?
