Length-contraction time-dilation fallacy & length measurement
In summary, the conversation discusses a fallacy in which an observer in the Earth frame attempts to measure the length AB by calculating the time interval between two events and then multiplying it by a velocity. The observer argues that an observer in the train frame would measure a shorter time interval due to slower moving clocks, resulting in a shorter length for AB. However, the conversation reveals that the train observer actually measures a longer time interval due to a lack of synchronization between the two clocks on the train. This leads to a contradiction and the need for a more precise understanding of when to apply length contraction and time dilation formulas.
Happiness
690
31
Suppose an observer in the Earth frame set out to measure the length AB by measuring the time interval between the event "B coincides with D" (event BD) and the event "A coincides with D" (event AD), and then multiplying the time with ##v##. This observer argues that an observer in the train frame would measure this time to be smaller since moving clocks run slower, and so would arrive at a shorter length for AB. But to the observer in the train frame, length AB is stationary, a proper length, and so should instead be longer. We arrive at a contradiction.
Where's the mistake?
Note: The train observer measures the time interval between event BD and event AD and then multiply it by ##v## to get the length AB. In the train frame, the Earth and hence point D are moving at speed ##v## too. The distance traveled by D during this time is the length AB.
I have arrived, I believe, at a resolution of the fallacy, which, from the tortuous, eventful fate of this thread—its being closed and subsequently eventually re-opened after much pleading and explanation—I deduce, confuses many people indeed, even the experts. Nonetheless, I would like to thank @TSny for providing the much-needed support, clarity and inspiration.
So what's more apt than to start the answer with TSny's words:
The train observer can indeed measure the length of the train by multiplying v by the time interval she measures between events BD and AD.
Also, the Earth observer does indeed measure clocks in the train to be ticking slower compared to his own clocks on earth.
Nevertheless, when the train observer calculates the length of her train using the method mentioned above, she will find the length of the train to be longer than the length of the train as determined by the Earth observer!
How can this be? Well, the key is to realize that the train observer must use two different clocks. The time of event BD according to the train observer is measured by a clock located at point B of the train. The time of event AD according to the train observer is measured by a different clock located at point A of the train.
Can you see a way in which the time interval between the two events as measured by these train clocks can be longer than the time interval as measured by the Earth clock (at D) even though the Earth observer measures the train's clocks as ticking slower than clocks on earth?
The space below is intentionally left blank so that you have a chance to work out the answer on your own first before looking at my answer.
If your answer is
Since the train observer measures a proper length, it must be longer than the length measured by the Earth observer. So the time measured by the train observer must be longer, since ##t=\frac{\mathrm{length\,AB}}{v}##.
, then you have not resolved the fallacy! You need to explain what's wrong with the fallacy, not just give the correct answer using a different method. Why don't slower clocks lead to a shorter length? My answer is below. So one last chance to work out the answer on your own first before looking at it.
Synchrony is the answer. Synchrony is not the same as simultaneity (though they are related). We don't invoke simultaneity because the train observer is not measuring the length AB via length measurements at the same instant. The two moving clocks on the train, the one at A and the one at B, indeed run slower than those on earth. But they are not synchronized! The clock at B is always ahead of the one at A by some fixed amount. So although the time elapsed by the two moving clocks are the same, say 15 s, and both are slower than the time elapsed on earth, say 20 s, the clock at B is always ahead of the one at A by say 7 s. In this case then, the time measured by the train observer (between event BD and event AD) is 15 + 7 = 22 s, longer than the time measured by the Earth observer, i.e. 20 s.
These 7, 15, 20 s are just wild guesses. I am sure all these figures can be made accurate and expressed in terms of ##v##, etc. But I am really busy at the moment for the next few days. So I shall just stop here and work out the math next time.
Below is an explanation on the non-synchrony of moving clocks:
Likes TSny
Yes, this is the mistake. In fact, the observer in the train frame measures the time between events BD and AD to be longer, not shorter, than the time between them in the Earth frame.
More precisely, they are not synchronized in the Earth frame. Yes, this would explain, from the Earth observer's point of view, why, even though the train clocks run slow as seen in the Earth frame, the time interval between events BD and AD is still longer in the train frame.
Yes that explains it.
Would you then agree that these sentences are in fact correct?
[Moderator's note: off topic comments deleted.]
They seem fine to me.
You just seem to have been making the classic mistake of trying to apply the length contraction and time dilation formulas without being wary of when they apply. Just figure out the coordinates of the events you're interested in and use the Lorentz transforms.
Likes Happiness
Happiness said:
some doubts and confusion on the following sentences, I believe, remain
No, they don't. The train observer can make the calculation you describe to determine the length AB in his frame. The mistake in your OP was in the Earth observer incorrectly thinking that the train observer's time between events BD and AD was shorter--in fact it's longer. Since it's longer, the train observer calculates a longer length AB than the Earth observer, just as would be expected from length contraction.
If you look, you will see that that entire previous thread on this topic has been deleted, since it's no longer applicable. It was not clear in that previous discussion what you were trying to do. Now that that's clear, this discussion is the only one you need to be concerned with.
It might be worth noting, in this connection, that the train frame observer's calculation is not quite the same as the Earth observer's calculation, as far as the physical basis of it is concerned.
The Earth observer is reasoning as follows: I have two ends of a moving object that both pass the same fixed point. Since I know how fast the object is moving, I can convert the time between the two ends passing to the length of the object, by multiplying by its known speed ##v##.
The train observer is reasoning as follows: I have two fixed points which a given moving object passes. Since I know how fast the object is moving, I can convert the time between the object passing the two fixed points, to the distance between those points, by multiplying by the known speed ##v## of the object.
These two calculations look similar mathematically--I take a time and multiply it by a speed to get a length--but they are not the same, physically speaking. One is calculating the length of a moving object as it passes a single fixed point. The other is calculating the distance between two fixed points that are passed by a moving object. Of course the results are related by length contraction, but they're still not quite the same kind of calculation physically.
Adding to Peter's last...
And one involves one clock, the other involves two clocks, making then fundamentally different types of measurement. It is impossible to perform, in the train frame, the type of measurement done in the Earth frame.
Likes PeterDonis
One more thought on this - there is a certain sense the train observer can use one clock - they just move a clock at a known speed along AB, and compute vt. But, of course, they know, or find that this method is flawed because the clock runs slow compared to their stationary clocks. However, in the limit as v goes to zero, the length measured this way approaches the proper length. So directly using the Earth measurement technique in the train frame with vanishing v works and explains the discrepancy with the Earth frame (the Earth frame is using 'fast clock transport' which produces too small a value. This method has a name - slow clock transport. Normally, it comes about as an alternative clock synch method that is equivalent to Einstein sync in the limit of vanishing v. Here, we use it to measure length instead.
Related to Length-contraction time-dilation fallacy & length measurement
What is the length-contraction time-dilation fallacy?
The length-contraction time-dilation fallacy is a common misconception that arises when trying to understand the concepts of length contraction and time dilation in special relativity. It is the incorrect belief that objects moving at high speeds will physically shrink in length and experience a slower passage of time when observed by an outside observer.
How do length contraction and time dilation actually work?
Length contraction and time dilation are phenomena predicted by the theory of special relativity. They occur when an object moves at high speeds, close to the speed of light. According to special relativity, the concept of time is relative and depends on the observer's frame of reference. This means that an object moving at high speeds will experience time passing slower than an object at rest. Additionally, length contraction refers to the observed decrease in the length of an object when it is moving at high speeds.
What is the relationship between length contraction and time dilation?
Length contraction and time dilation are closely related and are both consequences of the theory of special relativity. They both arise due to the fact that the speed of light is constant and the same for all observers, regardless of their relative motion. As an object's speed increases, its length will appear to contract and time will appear to slow down for an outside observer.
Can the length-contraction time-dilation fallacy be observed in everyday life?
No, the length-contraction time-dilation fallacy cannot be observed in everyday life. The effects of length contraction and time dilation are only significant at speeds close to the speed of light, which is much faster than anything we encounter in our daily lives. These effects are only measurable in highly controlled experiments or through advanced technology, such as particle accelerators.
How is length measured in special relativity?
In special relativity, length is measured in the observer's frame of reference. This means that an object's length will be measured differently by observers in different frames of reference, depending on their relative motion. This is different from our everyday experience, where we assume that an object's length is constant regardless of who is measuring it. Special relativity takes into account the fact that the speed of light is constant and the same for all observers, which leads to the concept of length contraction.
