MHB Length of Shortest Side In a Triangle
  • Thread starter Thread starter anemone
    Length Triangle
If \(a^2 + b^2 > 5c^2\), it can be proven that \(c\) is the shortest side of triangle \(ABC\). Assuming \(a\) and \(b\) are both greater than \(c\) leads to contradictions based on the triangle inequality and the given condition. The implications derived show that \(a^2 + ab + b^2 > 3c^2\), which supports the conclusion. The argument is reinforced by considering the triangle inequality, confirming that \(c\) must indeed be the shortest side. Thus, the proof is sufficient.
anemone
MHB
POTW Director
If $a,\,b$ and $c$ are the sides of a triangle $ABC$, prove that if $a^2+b^2>5c^2$, then $c$ is the length of the shortest side.
Mathematics news on Phys.org
Suppose we assume:
$$a>c\implies a^2>c^2$$
$$b>c\implies b^2>c^2$$
These two conditions also imply:
$$ab>c^2$$
Adding the three implications, we obtain:
$$a^2+ab+b^2>3c^2$$
The triangle inequality implies:
$$a^2+2ab+b^2>c^2$$
And, we are given:
$$a^2+b^2>5c^2$$
Adding these last two, there results:
$$a^2+ab+b^2>3c^2$$
As we initially found, this is the result of assuming both \(a\) and \(b\) are greater than \(c\). :)
Good job, MarkFL! And thanks for participating!
Solution of other:
Assume that $c$ is not the shortest side. Therefore we have $a\le c$, or $a^2 \le c^2$.
Adding $c$ to both sides, and square them yields $(a+c)^2\le 4c^2$.
By the triangle inequality we have $b<a+c$ and hence $b^2<(a+c)^2\le 4c^2$.
We then get $a^2+b^2<5c^2$, which reach to a contradiction and therefore, our assumption is wrong and $c$ is the length of the shortest side of the triangle.
MarkFL said:
Suppose we assume:
$$ab>c^2$$
$$a^2+ab+b^2>3c^2$$
$$a^2+2ab+b^2>c^2$$
And, we are given:
$$a^2+b^2>5c^2$$
$$a^2+ab+b^2>3c^2$$
Hello Mark
You have assumed c being the shortest side and you have taken the given condition as well. So I am not convinced that
the proof is right. You have taken both the condition and assumption and proved it.
If I have missed something kindly let me know.
kaliprasad said:
Hello Mark
I have assumed that \(c\) is the shortest side and shown how it leads to an implication provided both by the given and the triangle inequality. It seems to me this is sufficient. Is it not?
But does not prove that this is not true if c is not the shortest side which we need to prove
My apologies. You are absolutely correct. Suppose I arranged things in the following manner:
$$a^2+2ab+b^2>c^2$$
And, we are given:
$$a^2+b^2>5c^2$$
Adding these, there results:
$$a^2+ab+b^2>3c^2$$
Now, suppose \(a=3b\) and \(c=2b\):
$$9b^2+3b^2+b^2>12b^2$$
$$13b^2>12b^2$$
This is true, even though \(c>b\). I'll try to come up with a sound solution. :)
