Length, time and velocity in relativity (special?)
In summary, the average lifetime of a pi meson in its own frame of reference is 2.6 x 10^-8 s. When the meson moves with a speed of 0.95c, its mean lifetime as measured by an observer on Earth is 8.33 x 10^-8 s and the average distance it travels before decaying, as measured by an observer on Earth, is 23.8 m. To find the velocity of the particle measured on Earth, it is given that the meson moves with a speed of 0.95c with respect to the Earth.
weirdobomb
10. The average lifetime of a pi meson in its own frame of reference is 2.6 x 10^-8 s. If the meson
moves with a speed of 0.95c, what is (a) its mean lifetime as measured by an observer on Earth and
(b) the average distance it travels before decaying, as measured by an observer
on Earth?
(a) using the formula for time dilation
mean lifetime measured on Earth I found t = 8.12 x 10^-4 s
(b) I calculated the distance traveled in the particle to travel in its own frame L = 7.44 m
I took that value and used the formula for length contraction
average distance traveled measured on Earth before decaying L = 23.8 m.
I am pretty sure my answers are correct, or at least the concept is. My question is for (b), how do I find the velocity of the particle measured on Earth? What I want to do is take the Earth measured velocity to multiple by the answer from (a) to have a different way to answer (b).
I think I have to use the velocity formula in the attachment but doesn't that one require the particle to be moving in an already moving frame (v=velocity of frame u'=particle velocity in that frame).
Show what you did here. What value did you get for the Lorentz factor (gamma)?
I correct my answer to t = 8.33 x 10^-8 s which screws up everything. y = 3.2
I don't care about the answers for (a) and (b). I really want to know how to find the velocity for particle measured on Earth.
That's given:
weirdobomb said:
If the meson moves with a speed of 0.95c,
That's its speed with respect to the Earth. (Its speed with respect to itself is zero, of course.)
Can I just use the velocity formula without the frame velocity?
As a scientist, it is important to have a clear understanding of the concepts and formulas being used in a problem. In this case, we are dealing with the concepts of length, time, and velocity in the context of special relativity. Special relativity is a theory that describes how physical laws and measurements change when objects are moving at speeds close to the speed of light.
In special relativity, the concept of time is relative and depends on the observer's frame of reference. This means that different observers will measure different times for the same event, depending on their relative motion. The same applies to the concept of length, which also appears to change depending on the observer's frame of reference.
In this particular problem, we are dealing with a pi meson moving at a speed of 0.95c (95% of the speed of light) and its average lifetime in its own frame of reference, which is 2.6 x 10^-8 s. We are asked to find the meson's mean lifetime and the average distance it travels before decaying, as measured by an observer on Earth.
(a) To find the mean lifetime as measured by an observer on Earth, we can use the formula for time dilation, which states that the time measured by an observer in a moving frame is longer than the time measured in the stationary frame. This means that the meson's lifetime will appear longer when measured by an observer on Earth. Using the given values, we can calculate the mean lifetime as t = 8.12 x 10^-4 s.
(b) To find the average distance traveled before decaying, we need to use the concept of length contraction, which states that the length of an object appears shorter when measured in a moving frame than in a stationary frame. Using the formula for length contraction, we can calculate the average distance traveled by the meson as L = 23.8 m.
Now, to answer your question about finding the velocity of the particle measured on Earth, we can use the velocity formula without the frame velocity. This formula, v = u/(1-v^2/c^2)^0.5, is used to find the velocity of an object in a stationary frame when its velocity is known in a moving frame. In this case, we know the velocity of the meson in its own frame (u) and we want to find its velocity in the stationary frame (
Related to Length, time and velocity in relativity (special?)
1. What is the theory of relativity?
The theory of relativity is a scientific theory developed by Albert Einstein in the early 20th century. It explains how the laws of physics are the same for all observers, regardless of their relative motion. There are two types of relativity: special relativity and general relativity.
2. What is the difference between special relativity and general relativity?
Special relativity deals with the laws of physics in inertial (non-accelerating) frames of reference, while general relativity includes the effects of gravity and acceleration. Special relativity is based on the idea of the constancy of the speed of light, while general relativity explains gravity as the curvature of spacetime.
3. How does special relativity affect our understanding of length and time?
Special relativity states that length and time are not absolute, but are dependent on the observer's relative motion. This means that an object's length and the time it experiences can be perceived differently by different observers depending on their relative velocities.
4. What is time dilation in special relativity?
Time dilation is the phenomenon predicted by special relativity where time appears to pass slower for objects in motion compared to stationary objects. This means that time is relative to the observer's frame of reference and can change depending on their relative velocity.
5. How does special relativity affect the concept of velocity?
In special relativity, the concept of velocity is not constant and can change depending on the observer's relative motion. The speed of light, however, is constant for all observers regardless of their relative velocity. This is one of the fundamental principles of special relativity.
