Lense-Thirring effect - General Relativity
In summary, the toy-metric is a geodesic which is not a geodesic if the metric is singular at x=y=z=0.
Pentaquark5
Let us assume a "toy-metric" of the form
$$ g=-c^2 \mathrm{d}t^2+\mathrm{d}x^2+\mathrm{d}y^2+\mathrm{d}z^2-\frac{4GJ}{c^3 r^3} (c \mathrm{d}t) \left( \frac{x\mathrm{d}y-y\mathrm{d}x}{r} \right)$$
where ##J## is the angular-momentum vector of the source.
Consider the curve
$$ \gamma(\tau)=(x^\mu (\tau))=\bigg(t(\tau),0,0,z(\tau)\bigg) $$
To see wether this is a geodesic, we need to check if the geodesic equation in local coordinates
$$ \frac{\mathrm{d}^2x^\mu}{\mathrm{d}\tau^2}=-\Gamma^\mu_{\:\:\alpha\beta} \frac{\mathrm{d}x^\alpha}{\mathrm{d}\tau}\frac{\mathrm{d}x^\beta}{\mathrm{d}\tau}$$
is fulfilled.
In order to do that, we will need to calculate the Christoffel symbols where ##\alpha, \beta## equals ##r## or ##z##:
Along ##\gamma## we have ##g_{\mu \nu}=\eta_{\mu \nu}## and
$$ \Gamma^\mu_{\:\: z\alpha}=\frac{1}{2}\eta^{\mu \nu}\big( \partial_z g_{\mu \alpha}+\partial_\alpha g_{\mu z}-\partial_\nu g_{z \alpha} \big)=0 $$
Indeed,
$$ \partial_z g_{t y}|_\gamma = \partial_z \left( -\frac{4GJx}{c^2r^3} \right)|_\gamma = x\partial_x\left(-\frac{4GJ}{c^2r^3}\right)|_\gamma=0$$There are a few questions I have about this computation, and I would be really thankful for input:
Firstly, can we assume ##g_{\mu \nu}=\eta_{\mu \nu}## along the curve, since spacetime is locally Minkowski along ##\gamma##?
Secondly, am I missing something, or should the denominator of ##g_{t y}## be proportional to ##r^{-4}## instead of ##r^{-3}##?
And thirdly, since ##r=r(x,y,z)=\sqrt{x^2+y^2+z^2}##, shouldn't the derivation ##\partial_z g_{t y}|_\gamma## be nonzero?
Likes Emil_M
What makes you think this?
Hey, (I didn't know my PW by heart so I had to create a new account)
See the proof that every Lorentzian Metric is locally Minkowski on p.31 of this script: https://gravity.univie.ac.at/fileadmin/user_upload/i_gravity_physics/material/teaching/rt2/SS_2013/Vienna2013.pdf
That doesn't mean that ##g_{\mu \nu} = \eta_{\mu \nu}##. For that you have to choose an appropriate coordinate chart. The chart you are using does not do this, even at a point, so you can't use ##g_{\mu \nu} = \eta_{\mu \nu}## in your reasoning if you are using that chart.
This proof shows that you can choose coordinates such that ##g_{\mu \nu} = \eta_{\mu \nu}## at a single point. It does not show that you can do so such that ##g_{\mu \nu} = \eta_{\mu \nu}## along an entire curve ##\gamma##, which is what you claimed. It is actually possible to show the latter, but doing it requires a different choice of coordinates. And neither of these choices of coordinates is the one you used in the OP, so all this is irrelevant anyway.
Also the metric is singular at x=y=z=0, if I'm not mistaken.
Thank you for your answers!
I know that ##\eta_{\mu \nu}=g_{\mu \nu}## only holds point for point, which is why I was asking if this was the justification for setting ##\eta_{\mu \nu}=g_{\mu \nu}##: I couldn’t see how this would hold for all of ##\gamma## in those coordinates.
And just to avoid miscommunication: the above is copied from my script, it’s not written by me.
You need to find the Christoffel symbols first, then evaluate them on the curve, when you substitute the in the geodesic equations. And you cannot check that the curve is geodesic, it has unknown functions in it. You can use the geodesic equations to find ODE's for these functions. Their solutions will give you geodesic curves.
I’ve already done that. The geodesic is of the form ##(x(\tau))=(u^0,0,0,u^3)\tau## with ##u^0=\sqrt{1+(u^z)^2}##. Here ##u^0## and ##u^3## are constant.
However that does not answer the questions formulated in my OP.
Which question! The first was already discussed.
The second.
Pentaquark5 said:
Secondly, am I missing something, or should the denominator of ##g_{t y}## be proportional to ##r^{-4} ## instead of ##r^{-3}##?
The denominator of ##g_{ty}## is proportional to ##r^{-4}##. So I don't understand your question whether it should be. It is.
The third.
On the curve ##x=0##, so the derivative is zero on the curve, although not zero everywhere.
I’m still confused about the reason as to why it is legitimate to assume ##\eta_{\mu \nu}=g_{\mu \nu}## along ##\gamma##, as my script does.
It is not an assumption, it is a substitution. The Christoffel symbols and the components of the metric are functions. So to evaluate them at a point you plug in the point's coordinates. If the point is on the curve, the ##x## and the ##y## are zero.
It only holds at one point with a particular choice of coordinates. You keep missing this crucial qualifier. With different choices of coordinates, it could be that ##g_{\mu \nu} = \eta_{\mu \nu}## at more than one point. You have to look at the particular coordinates to see.
In the coordinates you gave in the OP, at any point where ##x = y = 0##, you will have ##g_{\mu \nu} = \eta_{\mu \nu}##. That's obvious just from looking at the line element, since the only term that differs from ##\eta_{\mu \nu}## is zero if ##x = y = 0##.
Related to Lense-Thirring effect - General Relativity
1. What is the Lense-Thirring effect?
The Lense-Thirring effect, also known as frame-dragging, is a phenomenon predicted by Einstein's theory of general relativity. It describes the effect of a rotating massive object, such as a planet or star, on the spacetime around it. This effect causes the rotation of the object to "drag" the surrounding spacetime, affecting the motion of nearby objects.
2. How does the Lense-Thirring effect differ from the other effects of general relativity?
The Lense-Thirring effect is a specific consequence of the general theory of relativity, while other effects such as gravitational lensing and time dilation are more general and can occur in a variety of scenarios. The Lense-Thirring effect specifically deals with the rotation of massive objects and its impact on the surrounding spacetime.
3. Can the Lense-Thirring effect be observed in our everyday lives?
The Lense-Thirring effect is a very small effect and is typically only observed in extreme scenarios, such as around rapidly rotating black holes or neutron stars. It is not something that can be easily observed in our everyday lives.
4. How is the Lense-Thirring effect significant in astrophysics?
The Lense-Thirring effect plays a crucial role in understanding the motion of objects in the vicinity of massive rotating objects, such as in the orbits of planets around the sun. It also has implications for the study of black holes and other exotic objects in the universe.
5. Are there any current or planned experiments to test the Lense-Thirring effect?
Yes, there have been several experiments conducted to test the Lense-Thirring effect, including the Gravity Probe B mission by NASA and the LARES satellite by the European Space Agency. Future missions, such as the Laser Interferometer Space Antenna (LISA), are also expected to provide further insights into this phenomenon.
