Lenz' law: North pole of bar magnet moves away from a coil
In summary, the EMF of a battery will create a magnetic field that will offset the effect of the bar magnet.
subhradeep mahata
120
You have a circular coil, and two metal plates a and b. The north pole of a bar magnet is moved away from the coil at a constant velocity(assume the bar magnet and the coil lies along the x axis). On which plate will the excess positive charge appear?
Since the north pole is moved away, a south pole will be 'induced' in coil , which will result in a clockwise current, so a-b should behave as a cell with positive terminal a and negative terminal b. But my book says that excess positive charge will appear at b. Where am i wrong?[/B]
You need to have a changing flux in the coil=I think the statement of the problem is slightly inaccurate and the perpendicular to the plane of the coil needs to face the north pole of the magnet. It is sort of apparent what they are trying to show with their sketch, so we can proceed from there. Do the magnetic flux lines from the north pole of the magnet go into the plane of the loop?=(assume the magnet is held above the loop with the north pole facing the loop. What happens when the magnet is pulled farther away from the loop?=do the flux lines decrease in intensity? What direction does the current need to flow in the loop to create a magnetic field to offset this effect?
That's what i am stuck at...according to me the current should flow in the clockwise direction
If it flows clockwise with positive charge flowing into capacitor plate "b", the positive charge flows into ## b ##. ("a b" is not a battery=it is a set of capacitor plates). ## \\ ## Additional comment: The EMF ## \mathcal{E} ## occurs inside the loop, but it is not indicated. It would be in the direction from a to b.
Can you please elaborate a little?
If the current flows clockwise, how can you say that positive charge will flow in plate b?
That is how a capacitor works. Draw a capacitor in series with a battery or other EMF. That's what happens.
Do you mean something like this?
The plate through which current enters behaves as a positive plate?
Likes Charles Link
Yes. And the EMF ## \mathcal{E} ## of the battery proceeds around the loop in the direction of current flow, proceeding inside the battery from the minus terminal to the plus terminal. The (positive) current flows into the previously uncharged capacitor giving it a positive charge on the upper plate, and positive current flows out of the previously uncharged lower plate, leaving behind a negative charge.
Thank you very much Charles Link, i understood it.
Likes Charles Link
Related to Lenz' law: North pole of bar magnet moves away from a coil
What is Lenz' law?
Lenz' law is a fundamental law of electromagnetism that states that the direction of an induced current in a conductor will be such that it opposes the change that produced it.
How does Lenz' law apply to a north pole of a bar magnet moving away from a coil?
In this scenario, the changing magnetic field from the moving north pole of the bar magnet will induce an opposing current in the coil. This current will create its own magnetic field that opposes the movement of the north pole, resulting in a repulsive force.
What factors influence the strength of the induced current according to Lenz' law?
The strength of the induced current is influenced by the rate of change of the magnetic field, the number of loops in the coil, and the resistance of the conductor.
How does Lenz' law relate to the conservation of energy?
Lenz' law is consistent with the law of conservation of energy as the induced current and resulting magnetic field create a force that opposes the original change, thus conserving energy in the system.
What are some real-world applications of Lenz' law?
Lenz' law is used in a variety of devices, such as generators, transformers, and induction cooktops. It is also important in understanding the behavior of eddy currents in conductors.
