Leptons and the Lorentz Group O(3,3)
In summary, the article discusses the internal symmetry space of O(3,3). It suggests that there are similarities between mathematical properties and relationships of leptons in the standard model and those of group theory algebras in O(3,3). This is an interesting finding and warrants further investigation.
Marty4691
This is note about O(3,3) space-time. The related article is:
https://doi.org/10.3390/sym12050817
Here's some background:
In O(3,1) space-time (Minkowski), the six generators of rotations and boosts can form an SU(2) x SU(2) Lie algebra. This algebra is then used generically by all the leptons so that their associated spinors obey special relativity.
In O(3,3) space-time (a mathematical space), the fifteen generators can form a number of SU(2) x SU(2) and related algebras. There are actually enough algebras to allow each lepton in the SM to transform under a unique algebra. This raises two questions, first, is there a one-to-one correspondence between leptons and algebras, and second, if this is true, which leptons are associated with which algebras.
Implications of the article:
The linked article investigates the internal symmetry space of O(3,3). The findings in the article suggest that: mathematical properties and relationships of certain group theory algebras in O(3,3) resemble mathematical properties and relationships of leptons in the SM.
Here's a breakdown of O(3,3):
O(3,3) has three O(3,1) subspaces (Minkowski) and three O(1,3) subspaces (associated with one space dimension and three time dimensions). Each of these subspaces is associated with a unique SU(2) x SU(2) subalgebra.
A spinor transforms under the spin 1/2 representation of an SU(2) x SU(2) algebra. In this sense, SU(2) x SU(2) algebras are "proxies" for spinors.
In O(3,1) space, the solutions of the Dirac equation are spinors and describe the time-evolution of a spin 1/2 particle in 3D space. Time is a c-number.
In O(1,3) space (a mathematical space), the solutions of the Dirac equation are spinors and describe the space-evolution in 3D time. Space is a c-number.
The linked article finds that: the units of measure for the conserved quantity due to invariance under rotations in time, are the same as those for the Planck constant. This is implies that spinors in O(1,3) space also have spin 1/2.
In the context of O(3,3), this gives us six spinors, split into two families each with three members. That is, spinors associated with O(3,1) subspaces in one family and those associated with O(1,3) subspaces in the other.
@Marty4691 is interested in discussing the mathematical points of his paper. He can explain it better than I So over to @Marty4691
jedi
Thanks jedishrfu.
Just to be clear: O(3,3) space is a mathematical space and the linked article makes no claims about the physics in O(3,3).
As mentioned above the mathematical properties and relationships of some group theory algebras in O(3,3) overlap with the mathematical properties and relationships of leptons. The question is whether this is just a coincidence or warrants further investigation.
Any feedback is appreciated.
The difficult part is relating the physics to the math and this has been pursued in a number of other papers (in the context of SO(3,3), which eliminates the improper lorentz transforms), so it seems worth investigating. For example, the paper below looks at SO(3,3) and a potential connection of gravity and EM, but interprets the extra dimensions differently.
https://cds.cern.ch/record/688763/files/ext-2003-090.pdf
Likes Marty4691
Thanks bobob.
But e.g. when you rotate a physical system, there isn't a separate rotation group for each species of lepton. The same spatial rotation acts on everything at once.
There are independent lepton family number symmetries but they are only U(1).
That's true in the standard model, but presumably the only point of doing any physics along these lines is to look for something that fails in the standard model. Lepton family number (as per your example) is something that has been looked for experimetally in several different types of experiments and although the limits on violation are really stringent (aside from neutrino oscillations which violate lepton family number for neutrinos) , no one has a good explanation for why it should be so, but it begs an explanation. Also, at least according to what most believe, black holes violate those standard model symmetries.
Most if not all of physics, at some level, seems to come down to finding a larger group to encompass everything else (including gravity) and breaking symmetries. Basically, it comes down to a question of, is the mathematics correct? Can it be made to describe things we measure (in principle) in a simpler way than what we have now? At this point in time, I don't think anyone has a good idea of where there is any new physics, so starting with some mathematics and finding a way to make an experimental prediction about something new that hasn't already been ruled out is pretty much par for the course in HEP. (Obvious examples are minimal SU(5), which was ruled out by the proton lifetime, supersymmetry, which will probably always be "just out of reach of the current accelerators," etc.)
In the case at hand, I think the only question is to what can you apply this symmetry to make an experimentally testable prediction about something we don't know? If the OP does that, great. If not, it will just be a somewhat different attempt to look at almost the same symmetries a number of others have tried.
Related to Leptons and the Lorentz Group O(3,3)
What are leptons?
Leptons are a type of fundamental particle that make up matter. They are considered to be one of the building blocks of the universe, along with quarks and bosons. Leptons have a spin of 1/2 and are not affected by the strong nuclear force.
What is the Lorentz group O(3,3)?
The Lorentz group O(3,3) is a mathematical group that describes the symmetries of space and time in special relativity. It is a 6-dimensional non-compact Lie group that includes rotations and boosts in three-dimensional space and time. It is important in understanding the behavior of particles in high-energy physics.
How are leptons related to the Lorentz group O(3,3)?
Leptons are affected by the symmetries described by the Lorentz group O(3,3). This means that their behavior and properties are affected by the principles of special relativity, such as time dilation and length contraction. The Lorentz group also plays a role in the interactions between leptons and other particles.
What are the different types of leptons?
There are six types of leptons: the electron, muon, tau, and their corresponding neutrinos. Each lepton has a corresponding antiparticle with opposite charge. The electron, muon, and tau are all negatively charged, while their corresponding neutrinos are electrically neutral. These particles are organized into three generations, with each generation having increasing mass.
What is the significance of leptons and the Lorentz group O(3,3) in modern physics?
Leptons and the Lorentz group O(3,3) are essential in understanding the fundamental laws of nature, particularly in the field of high-energy physics. They provide a framework for understanding the behavior of particles and their interactions at the smallest scales. Additionally, the study of leptons and the Lorentz group has led to important developments in theories such as quantum field theory and the Standard Model of particle physics.
  • Beyond the Standard Models
