taylaron
- 1
Greeting PF’rs
Subject: Levitation using directed electric fields
If someone had a way to take a spherical mass and pump electrons into the mass and fill many of the valence electron shells in the atoms, there would be an enormous electric field emitted by the charged mass. (Yellow sphere in illustration). Because the electrons experience the coulomb force against one-another, the electrons would be driven to be equally spaced throughout the charged mass. Coulombs law would obviously be valid because the area in the exact center of the mass would be uncharged.
To prevent electrical discharge, the mass would need to be surrounded by a strong dielectric, say- ultra pure water of PTFE.
The electric field emitted by the object would induce charge separation in objects nearby. If the E field was strong enough and the object was above the charged mass, the object would experience upwards force exerted by the E field on the electrons in the object.
Because a charged mass the repels nearly everything nearby wouldn't be very useful, a Faraday cage would be placed around the ultra pure water, acting to block the E field lines emitted by the charged object and a hole in the Faraday cage would allow for E field lines to be emitted in only a select direction.
Ignoring the amount of electrons necessary to induce any significant repulsive force, and my conceptual understanding is correct:
1. Would a hole in the circular Faraday cage (bottom of my illustration) allow the electric field lines to extend into infinity as shown? Obviously the repulsive force decreases with the square of the distance.
2. I’m not totally familiar with the effects of a Faraday cage. Would most of the electric field lines not naturally exiting the hole in the cage be redirected out of the hole? In other words, is the field line density only proportional to the cross section of the exposed charged mass?Cheers,
-Tay
-Tay
