L'Hopital's rule for solving limit
In summary, for the limit problem 1, L'Hopital's rule can be applied since it is in the form 0/0. For the second limit problem, taking logarithms of both sides and applying L'Hopital's rule can help solve for the limit.
mousesgr
31
1. lim [(1+x)^(1/x) - e ] / x
x ->0
2. lim [sin(2/x)+cos(1/x)]^x
x -> inf
help...
Homework should be posted in the homework forum- and you should show us what you have tried to do. Have you considered L'Hopital's rule?
qs 1 is not 0/0 or inf/inf from
how do consider L'Hopital's rule?
Do you KNOW "L'Hopital's rule"? It is specifically for limit problems where you get things like these.
If you have [tex]lim_{x->a} \frac{f(x)}{g{x}}[/tex] where f(a)= 0 and g(a)= 0, then the limit is the same as [tex]lim_{x->a}\frac{\frac{df}{dx}}{\frac{dg}{dx}}[/tex].
If you get things like [tex]0^0[/tex] or [tex]\infty^{\infty}[/tex] (as your second limit), you can take logarithms to reduct to the first case.
#1 is in form 0 / 0.
Since:
[tex]\lim_{x \rightarrow 0} (1 + x) ^ {\frac{1}{x}} = e[/tex]
So the numerator will tend to 0 as x approaches 0. The denominator also tends to 0. So it's 0 / 0.
You can use L'Hopital's rule to solve for #1.
#2 is [tex]1 ^ \infty[/tex]
First, you can try to take logs of both sides.
So let [tex]y = \lim_{x \rightarrow \infty} \left[ \sin \left( \frac{2}{x} \right) + \cos \left( \frac{1}{x} \right) \right] ^ x[/tex]. So:
[tex]\ln y = \ln \left\{ \lim_{x \rightarrow \infty} \left[ \sin \left( \frac{2}{x} \right) + \cos \left( \frac{1}{x} \right) \right] ^ x \right\} = \lim_{x \rightarrow \infty} \ln \left[ \sin \left( \frac{2}{x} \right) + \cos \left( \frac{1}{x} \right) \right] ^ x[/tex]
[tex]= \lim_{x \rightarrow \infty} x \ln \left[ \sin \left( \frac{2}{x} \right) + \cos \left( \frac{1}{x} \right) \right] = \lim_{x \rightarrow \infty} \frac{\ln \left[ \sin \left( \frac{2}{x} \right) + \cos \left( \frac{1}{x} \right) \right]}{\frac{1}{x}}[/tex]
This is 0 / 0. So again, you can apply L'Hopital's rule to find the limit.
Viet Dao,
FAQ: L'Hopital's rule for solving limit
What is L'Hopital's rule for solving limit?
L'Hopital's rule is a mathematical concept that allows us to find the limit of a function when the limit of the numerator and denominator both approach zero or infinity. It states that if we have a fraction where both the numerator and denominator approach zero or infinity, then the limit of the fraction is equal to the limit of the derivative of the numerator divided by the derivative of the denominator.
When should L'Hopital's rule be used?
L'Hopital's rule should only be used when we have a limit that is in an indeterminate form, such as 0/0 or ∞/∞. It cannot be used for limits that are already in a determinate form, such as 3/5 or ∞/2.
What are the steps for using L'Hopital's rule?
The steps for using L'Hopital's rule are:
  1. Determine if the limit is in an indeterminate form.
  2. Take the derivative of the numerator and the denominator separately.
  3. Simplify the new fraction.
  4. Take the limit of the new fraction.
  5. If the limit still results in an indeterminate form, repeat the process until a determinate form is obtained.
Are there any limitations to using L'Hopital's rule?
Yes, there are limitations to using L'Hopital's rule. It can only be used for limits that are in an indeterminate form, and it may not always result in the correct answer. It is also important to note that the rule only applies to certain types of functions, such as rational functions.
Can L'Hopital's rule be used for limits involving trigonometric functions?
Yes, L'Hopital's rule can be used for limits involving trigonometric functions. However, we must first convert the trigonometric functions into their equivalent exponential form before applying the rule.
