Liénard–Wiechert potentials: Local or Material derivatives?
In summary, the conversation discusses the effects of accelerating charged particles on charge potentials and the radiation of electromagnetic waves. It is noted that in the case of a continuum charge/current distribution, the equations for the Liénard–Wiechert potentials only seem to consider accelerations that alter the local field over time, rather than accelerations along the pathlines of the charges. The footnote mentioned in the conversation suggests using the retarded propagator to integrate the Maxwell equations for time-dependent sources.
particlezoo
113
If I took a charged particle and accelerated it, that acceleration would have an effect on charges potentials, allowing for the radiation of electromagnetic waves. This acceleration would be local to a point in spacetime and the observed potentials would depend on the frame of reference of the observer.
However, if I had a train of such accelerating particles such that they formed constant current and charge density distribution, then I could have a situation where the fields wouldn't change, and in principle, the system would not radiate.
I know I posted about something similar before, but I am still curious as to why in the case of continuum source distributions, it appears in some equations of interest that the only accelerations that seem to matter are the ones that alter the local field over time.
If we use the Lorenz gauge, it is clear from the Liénard–Wiechert potentials that for a source charge q which is accelerating that its vector potential would change a rate determined in part by its acceleration. However, none of this acceleration appears to be apparent in the equations describing the Liénard–Wiechert potentials for a static continuum charge/current distribution. Since streamlines are not necessarily pathlines, the local currents (which follow the streamlines) are not necessarily moving in the same direction as the charges themselves (which follow the pathlines). It would seem that to extend the Liénard–Wiechert potentials from the form of moving independent charges to continuum charge/current distributions requires that we consider accelerations of charges along pathlines which may exist even if the flow field is unchanging.
However, in the literature the partial derivative of the vector potential over time is ∂A/∂t, which depends on the current densities of the sources. And yet, if we were to take into account the contribution to the change in the vector potential due to each source charge density, shouldn't the superposition then reflect the material derivative associated with these moving sources (hence DA/Dt) rather than the sources' local derivative (hence instead of ∂A/∂t)?
- Kevin M.
May be the foot note in "5.2 Biot and Savart Law" in Jackson third Edition can help you
Well, the footnote is rather cryptic. The point is that for time-dependent sources (charge-current distributions) you have to take the retarded propagator to integrate the Maxwell equations. For the four-potential the equation is the wave equation (Heaviside-Lorentz units),
$$\Box A^{\mu}=\frac{1}{c} j^{\mu}.$$
The retarded solution, corresponding to outgoing waves from the sources, reads
$$A_{\text{ret}}^{\mu}(t,\vec{x})=\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x}' \frac{j^{\mu}(t-|\vec{x}-\vec{x}|/c,\vec{x}')}{4 \pi c |\vec{x}-\vec{x}'|}.$$
That's it! Of course, for time-independent sources you get back the Coulomb Law for ##A^0## (which becomes the electrostatic scalar potential), and the Biot-Savart Law for ##\vec{A}##. In this case you get the results of the Coulomb gauge, because for time-independent potentials the Lorenz-gauge fixing condition becomes of course the Coulomb one.
Related to Liénard–Wiechert potentials: Local or Material derivatives?
What are Liénard–Wiechert potentials?
Liénard–Wiechert potentials are a set of mathematical expressions used in classical electromagnetism to describe the electromagnetic field generated by a moving point charge. They take into account both the effects of the charge's motion and the time delay of the electromagnetic signals.
What are local derivatives in the context of Liénard–Wiechert potentials?
Local derivatives refer to the derivatives of the potentials with respect to the position of the charge at the present moment. These derivatives are used to calculate the electric and magnetic fields at a specific point in space due to the charge's motion at that same instant.
What are material derivatives in the context of Liénard–Wiechert potentials?
Material derivatives refer to the derivatives of the potentials with respect to the position of the charge at an earlier moment in time. These derivatives are used to calculate the electric and magnetic fields at a specific point in space due to the charge's motion at an earlier time, taking into account the time delay of the electromagnetic signals.
Why are Liénard–Wiechert potentials important in classical electromagnetism?
Liénard–Wiechert potentials provide a precise and accurate mathematical description of the electromagnetic field generated by a moving point charge. They are essential for understanding and predicting the behavior of electromagnetic radiation, and they have many practical applications in fields such as telecommunications, electronics, and astrophysics.
What are some limitations of Liénard–Wiechert potentials?
Liénard–Wiechert potentials are based on classical electromagnetism and do not take into account the effects of quantum mechanics. They also assume a point charge, which may not accurately represent the behavior of more complex charged objects. Additionally, they do not take into account the effects of non-uniform motion or acceleration of the charge.
  • Mechanics
  • Classical Physics
