Lifting an Elephant with Hydraulics: A Physics Puzzle
The discussion revolves around a physics problem involving a hydraulic lift supporting a 1200kg elephant and two 70kg students. The calculations initially suggest that the elephant should rise due to the pressure differences created by the students' weights on the smaller piston compared to the larger piston supporting the elephant. However, confusion arises regarding the balance of pressures, with one participant noting that the pressure exerted by the students is greater than that on the elephant's side. The participants also discuss the potential impact of the pistons' weights on the overall system. Ultimately, the problem remains unresolved, with a need for further clarification on the hydraulic mechanics involved.
kikko
The 70kg student in the figure balances a 1200kg elephant on a hydraulic lift. A second 70kg student joins the first student. How high do they lift the elephant?
diameter of the piston elephant is on = 2.0m
diameter of the piston student is on = 0.48m
The liquid inside the lift is oil, therefore rho = 900 kg/m3
Out would be elephant, In would be the students
Fout/Fin = Aout/Ain
Fout=Aout/Ain x Fin - \rhoghAout
(1200)(9.8) = ((pi*(2/2)^2)/(pi*(.48/2)^2))*(2)(70)(9.8) - (900)(9.8)(h)(pi)
h = .435m = 43.5 cm
This answer comes out wrong. I noticed the .435^-1 = 2.3m, and the answer is 2.3 cm, but I'm not sure if there is a relation there.
Anyways, any tips in the right direction?
Initially, the problem looks to be invalid.
Are you sure the elephant is on the larger piston?
kikko said:
Yes. Here is a picture, I solved .48 for the diameter of the first piston and got it correct.
http://session.masteringphysics.com/problemAsset/1070646/3/15.P41.jpg
Yes, of course. After thinking about it a bit more that makes sense.
But, I don't see how they can be in balance.
There would have to be equal pressure on each side of the system.
On the student's side, you have:
\frac{70 kg}{(0.24)^2 \pi ~m^2} = \frac{70 kg}{(0.576) \pi ~m^2} \approx \frac{70 kg}{0.181 ~m^2} \approx 386.83 ~kg/m^2
On the elephant's side, you have:
\frac{1200 kg}{(1)^2 \pi ~m^2} = \frac{1200 kg}{\pi ~m^2} \approx \frac{1200 kg}{3.142 ~m^2} \approx 381.97 ~kg/m^2
So, since there is more pressure being exerted on the oil on the student's side than on the elephant's side, the elephant should be rising (at least to the extent that shortest piston's travel allows, which means either the student's piston "bottomed out," or the elephant's piston "topped out.")
Now, if the student only weight 69.12 kg, you'd have:
\frac{69.12 kg}{(0.24)^2 \pi ~m^2} = \frac{69.12 kg}{(0.576) \pi ~m^2} \approx \frac{69.12 kg}{0.181 ~m^2} \approx 381.97 ~kg/m^2
which is the same pressure that's being exerted on the elephant's side.
... I think the weight of the pistons would affect the system though.
9K
9K
13K
